brucelucenta
- Joined
- Jul 21, 2013
- Messages
- 1,924
This was at the end of Philco washers. Probably the nicest and fanciest machine they made. I had a set of these once upon a time. The washer washed fairly well, but would spin out about as well as a Kenmore of the same vintage. The dryer was extremely slow and took much longer to dry than most. It was also difficult to clean the lint trap. You had to unfasten the bottom panel and empty a wire mesh cylinder that held the lint. It did have a glass door insert like a front load washer and there was a combination washer/dryer that looked the same as this set also. But this was at the tail end of the run for Philco. Probably about a 1968 model, since they did not make it into the 70's.
