Tangentially......
..... there IS such thing as 220V. I live in it. Built 15 years ago to the month. Measured 218V, and standard plugs are 125V. So the building runs on 3-phase and the ratios have been jiggered slightly to put 5V more on each leg, thus 10V more between 120* phases. We throw away an astonishing volume of fluorescent lamps, I have never seen them 'all' operating correctly at any time, even right after the electricians have been here. The performance of the 240V stove is 'disappointing' to put it politely. The coinop dryers take the same 40 min that my 120V LK does, with slightly larger capacity.
Other than load balancing the only thing in the building that actually USES 3-phase is the elevator pump.
So yes, you CAN have 220V running your 240V appliances. And you won't like it.
