thanks
yea it's got some rust doesn't it but underneath it looks great, turns easily, bearing sounds good, motor looks good, rollers great! the guy said water had set in it a long time.
as for the pump, thanks but i don't use pumps on mine. i take them off and gravity drain em. that's what i am workin on now on my custom imperial, installing a second drain in the outer tub using a peice from a pool supply house. it's 1 and 1/2 inches in diam pvc, i have hole cut in outer tub already, gettin ready to prime paint it.
i did find a new pump seal from larry in parma for rollermatic pumps, if you need one he may have more. dave from dave's repair on the web is advertising them also.
glad you got your pump fixed.
