Designgeek
- Joined
- Dec 12, 2004
- Messages
- 865
Ahh yes!, as I expected: lift out the clothes-ball, drop it into the tumble dryer, and it automatically "untangles" and "unwrinkles." That's taking "automatic" to a whole new level!
Very interesting explanation on Maytag's part, about the tangle or "wrap" factor. Makes perfect sense. With a center agitator, you lift out one piece at a time and don't tend to notice the fact that shirt sleeves are wrapped around pants legs and so on. Or you notice but it's "not remarkable" since it's always happened that way. But w/o a center agitator, you see a ball of clothes and immediately assume it's tangled, which it's not. But lifting out the whole load in one neat ball, ready to drop into the dryer, is way way cool. Question is, does the matching dryer have a reversing-drum feature where it reverses direction of rotation every so often throughout the cycle?
I figured Maytag had to have put a decent amount of engineering smarts into that design, and it would work properly for anyone who had one and understood how it was supposed to work.
What they really need for this is an animated cartoon ad showing how you use it, and that you can just "dump in" the load w/o arranging items around an agitator, and then lift out the clothes-ball in one swoop, drop it in the dryer, and the dryer separates it all back out again. This could be illustrated very easily nowadays.
I hope they keep it in the product line. Seems to me the best of both worlds in a way, i.e. most of what people like about TLs and the efficiency of a FL, plus vertical axis spin to reduce vibration. And no door seal. Only thing it lacks is a window in the lid, but obviously that's not essential seeing as Gansky was able to bypass the switch easily enough.
What I'd like to see next is one of these with a rotary knob for setting the cycles. For some reason I just can't get used to seeing washers with a bunch of flat touchscreen buttons on them instead of a knob. Hmm!
