Speed Queen the Only "Sane" Modern Washer Left?
Aug 5, 2011
15
Dullsville, Washington
The title is my humble opinion for the time being, depending on how my stubbornness wants to play out xD.
My family bought a speed queen washer, thanks in part to Youtube user DanManTN showing how this washer takes after older machines being simplified enough for old farts, while tending to fabrics with care with a more classical method of agitation.
This machine replaced the Whirlpool washer we had since we tossed our Kenmore BD after the motor went up in smoke a year after moving into our home. I still recall my brother having difficulty with his "Th"'s saying, "it has a squirter sing, to squirt!" However mom got aggravated with the machine stinking up the clothes with mildew and mold as the machine would neutral drain leaving a ring of scum at the top of the machine. So here came the Speed Queen to save us some grief.
To put it shortly, mom digs the new rig, and it hasn't let us down yet....Now if I could recall when we got it...
The only personal two downsides I have to this machine is the center seal that is destined to go bad, and the factory maximum water level setting. The washer only fills about 3/4 full on the maximum setting, and if you were to adjust this, you would have to turn a bolt on the water level switch located inside the control panel. To give folks a harder time adjusting this, thread locking goop has been placed on the switch to hinder folks from adjusting the water level switch. Pure aggravation if you ask me...I adjusted it tho, carefully.
The reason for this title, is because I feel that other brands have totally abandoned a sense of "simplicity" and added complications that hinder the cleaning of clothes, and make it more difficult for some folk to use.
Whirlpool/Kenmore totally abandoned their DD model only keeping the top end portion of the machine, and introduced a new motor/drive-train mechanism which is a great idea in terms of updating their older design. However, this is hindered by the suspension design where you can give this machine whiplash with the touch of a finger. Tuber's have complained at the machine taking far longer to complete a cycle as a load goes out of balance much easier than it did with the direct drive model (To compare, our Speed Queen barely went out of balance upon washing two heavy machine washable pillows). You also cannot let these machines fill with the lid open, as they must remain closed, and the automatic water level sensors have been problematic for some YouTubers clothing too.
GE has had its fair amount of issues with its electronic control boards causing malfunctions with their machines. One tuber I am subscribed too has an issue with a mode shifter causing the spin basket to turn during agitation - a flaw in the electronic control board.
Speed queen seems to be the only modern washer (correct me if im wrong) to have mechanical timers, switches, etc. As other modern washers are fraught with proprietary control boards which are expensive to replace and are unrepairable upon failure. Although a front loader - I recall repairing a friends Maytag Neptune with an irreplaceable blown fuse on an electronic control board, which required DE-soldering the bad fuse, or replacement of the entire control board.
So after this two hundred page ramble session, would you say that Speed Queen is the only "Sane" washer left?
These are just my opinions, I am an old man stuck in a young guys body, so I can be pretty grumpy at some modern devices at times :D
I'm a young man stuck in an old guy's body and I dislike the 'newfangledness for no dawlgone dagflabbed good reason' too. This retirement ghetto doesn't allow personal laundry equipment but I still own a 'basic' mechanical timer frontloader I bought in 1998 and in the 14 years it ran nothing went wrong and it didn't even stink. It's even simpler than a SQ. Motor, belt, standalone pump.
You are not alone
I love my SQ as well, I understand Alliance laundry the manufacturer of SQ washers has changed the seal from it's previous owner's design (Amana, Raytheon.) The Raytheon Amana machines which are identical to the Alliance Speed Queen machines had many premature seal failure issues. Alliance / SQ changed the seal design, and addressed this issue, so I do not think we will have seal issues..(fingers crossed) even if I did, I would go back out and buy another SQ...there really is no other choice....The last best Kenmore washer was made by Whirlpool around the year 2000.
Mike
I concur
I looked long and far and SQ is the only machine that does what it needs to do without a ton of useless unreliable features that do nothing buy jack up repair bills.
Hopefully Alliance can continue to make these machines for some time to come.
Don't know if it's the only sane washer left, but it was the only one we could find when we needed one several years ago.
Glad to see SQ/Alliance getting the respect they deserve, but I'd kill for a neutral drain on these machines. Much less hair/dirt/gunk in a load of wash water gets redeposited on clothes during a neutral drain, which is why Lady K's and other higher-end washers used them for so many years.
Neutral drain
Hi Jeff
Speed Queens for export to Australia actually have neutral drains with electric pumps and have been this way for many years, specifically to counteract any linting issues.
I'm sure there could be a way of retro-fitting a US Speed Queen, but not sure how.
Cheers
Leon
Leon, thanks for the info. I wonder if it's just a matter of swapping out the timers to get a neutral drain?
Timer swapping
Hi Jeff
I think it probably would be about swapping timers. I'll have to have a look at what information i have and see if i have any wiring diagrams which show this.
I do know there was a 'kit' available to repairmen here in Australia to retro-fit the early Speed Queen/Kleenmaid machines from spin-drain to neutral drain, whatever i find i can email you.
Cheers
Leon
Current SQ Top Load Washers
Hi Coreyere, I am glad you and your family are enjoying your SQ TL washer, they are refreshingly simple to use and understand, which is why we sell so many of them.
SQ put the thread lock on the water level adjustment screw NOT so you could not change it, but so the adjustment would not move on its own, and, if you readjusted the water level you would be wise to put a little thread locking material or even nail polish on the screw threads.
The center main seal has been greatly improved , BUT all washers with a moving water seal at the bottom of a tub full of water could eventually have a serious problem, this was also true GE FF, MT Helical Dr washers, Norge, current GE TL washers and now WP built belt drive and higher end direct drive Cabro style washers. The seal design of the old WP BD and the WP DD washers did not have this kind of troublesome main water seal which is a main reason that these washers often lasted so long under adverse usage conditions.
I to wish that SQ would go to a neutral drain system and while ND is not a perfect way to get the dirty water out of the washer it is FAR BETTER than trying to spin the load while draining. When the tub starts spinning and draining at the same time any scum on top of the water is immediately sent down into the center of the load and strained and forced through the clothing. Any sediment and much of the lint still in the load is also forced to the side with the clothing and held there by the spinning force and the clothing, if the tub was not spinning at this point more of this sediment and lint would just drain away with the exiting water through the holes in the bottom of the tub. This action is VERY WELL PROVEN.
WP went to a lot of extra expense when designing and building their BD washers to make them ND and EVERY WP built BD washer through 1987 NDed. WP tried to cut cost when they introduced the DD washer in 1981, but the poor results quickly caught up with them [ we were actually taking back DD washers and giving the customer BD washers in the mid 1980s beaus of linting complaints ] and therefore they devised a clever way to make the new DD system ND.
Every TL washer in the world uses ND now and if SQ keeps making TL washers much longer you will also see it on new SQs.
John L.
Many maytags, GM Frigidaires were spin dran also
And I don't remember reading any complaints about lint or excess dirt remaining in the clothes. Even looking through many CR back issues I don't see any notation of excessive lint or dirt.
FWIW, the GE profile I had was a neutral drain. The SQ is a spin drain and I cannot see any difference at all in the end results after a spin.
From a manufacturing perspective, with SQ having a spin drain, that eliminates another electrical connection. The pump can remain on the motor or in the case of the old models, be driven by a separate belt. I would assume that a reversing motor is a tad bit cheaper than 4 ft of wiring plus an electro-mechanical pump.
considering the pump out height of a SQ is not all that high.....an electrical pump may be more helpful for many installs, running high speed all the time versus the slower motor speeds....
and sometimes helpful should the main motor give out, at least you can still drain the machine for service.....
not everyone has the perfect station for washer installations...
the Neutral drain, if anything, takes the heavy load off the machine before the spin....and lowering the load of clothing gives it more of a center a gravity for balancing....
there are pros and cons in every situation....
New Whirlpool Belt Drive
I have model number wtw4800xq and its isn't a bad washer in my opinion. These washers have to be loaded correctly. I separate my loads according to whether their pants, shirts, hoodies, or sheets and get perfect results every time. The casual cycle takes about 33 minutes and is good enough for whatever I wash. If i have really dirty greasy clothes from work, they go in on the super wash cycle which is a looonngg cycle however i like it because of the long agitation stroke that produces great turn over with excellent results every time. The washer will fill with the lid open and has the older style water level pressure switch. The tub fills to the very top on the super water level setting, large, medium and even small settings produce enough water in the tub for excellent turnover no matter what size load i wash. I also like the fast spin. Clothes come out with less water and dry faster in my old GE dryer.
Now the Bad
I hate the lid lock! The first day i got the washer home, even before I ran the first load, I disabled it by taking the mechanism out of the lid and sticking it in the lock. I like to be able to lift the lid and see whats going on. I dislike how long it takes to fill the washer. I believe there are restrictors in the water supply valve. I contemplated removing them but i didnt want to risk screwing up a brand new washer lol. If its possible to do that someone please let me know :) It cant handle my comforter. Its too heavy and the machine cannot balance the load. I repaired my old model 70 and use it for my really heavy stuff.
So, the control board doesn't care if lid switch is never cycled? Some washers with electronic control will disable the washer if it doesn't detect opening/closing of the lid within a certain number of wash cycles.
yes, you have to pull the lid switch actuator out after every load to reset the machine.....odd, but it has to be done....not the best bypass of a switch, but it gets us thru....
I took the restrictors out of mine, take off the hoses, pull out the plastic screens, reach in with needlenose pliers and pull out that little black circular washer inside, push the screens back in, and re-attach the hoses......made a world of difference during fill time...otherwise it seemed to take forever...they can be put back in place just as easy...
Ok I just typed 2 paragraphs apparently adding any faces deletes it all...GRRRR
Any way,
After using a speed queen as a daily driver for nearly a month Im monster happy with it, and its way better over any machine sold in the last 10 years by a long shot. Built like a machine from the early 80s. It is the only sane washer out there and as would be their front loaders. The newer whirlpools are way to slow, they fill slow, pump out slow, spin takes sometime to ramp up plus the machine pauses for long periods during the cycle all in the name of energy. I regret to say but outside of speed queen the new top loads are gone. The newer Whirlpools also no loner seem to have an adjustable pressure switch but rather the control board decides that even on the models with a fill water level selector nob.
In my experience spin draining is something I prefer. Lint and dirt  seems to be centrifugally pulled away from the clothes rather than just being strained through the clothes then being folded into the ridges during the spin.  Spin draining also brings the clothes up higher which pulls more water out in the end, plus less wrinkling since the clothes don't clump up at the bottom.
chetlaham I dig the spin drain
Back when CR actually did half way decent reviews and they used charts to rate washers, SQ along with Maytag and pre WCI Frigidaire were never knocked for their spin drain process.
I notice no more lint than I did with my neutral drain GE.
After following
and learning what I have from this thread even though I dont need a new machine at the present Im giving some serious consideration to buying a new SQ (before even they go the way of electronic controls) and keep in storage for future use. Or at the least buy a few used SQ.
BUY a Speed Queen! :)
I don't think you will regret it. When they do finally turn the top loaders into high efficiency machines (Im sure as I type they are testing prototypes) the certainly will not be the same. The commercial models are already pilot testing a cool down as a full rinse where half the water is drained out then refilled. I would definitely keep in storage for future use it will be like buying a normal machine brand spakin new while no one else can... priceless!
