Speed Wash(Hot) / Heavy Soil / Turbo Wash.
Internal heater stopped heating right at the moment the drain pump engaged -- temperature at that time was 98 Fahrenheit. At no other point have I ever seen the internal heater kick in, so only wash, never rinse cycles. I forgot to measure the initial fill of warm water (as you know, even though Hot was selected as temp, LGs still fill with only luke-warmish water), so based upon previous experience I'd estimate the fill temp to be right around 86-90F. I'm definitely seeing the atomizer engaging at the end of the wash cycle, perhaps as a suds suppresor?, and during the spinning/water-extraction phase to aid in rinsing. By the way, I always use the Turbo Wash option when I use Speed Wash. Not sure if you're doing that or not. It's not default, not sure why not.
