Interesting that I'm only seeing one deep rinse on the cycles I've tried. From what you say, it's because I use Turbowash exclusively. Didn't know that. Good to know, more fun to come experimenting. Thank you. But I don't think I could stand to watch without the Turbo Jets streaming ;'D
I love the Speedwash cycle ( 4 minute default wash time on mine) and I use it all the time, firstly because I wash a lot of small loads frequently , and secondly because it's so familiar to me almost like vintage washing where the load takes about 30 minutes; it is never done in 15 real time--only in LG clock time--because the spin ritual adds about another ten minutes. Thirdly, because you get all the signature LG drama compressed into a short sequence, and fourthly , the missing spin allows more retention of detergent fragrance which is important to me. The main drawback for the those with sensitive skin is that there is no spin between wash and rinse; and THAT is how they keep it speedy. Aren't you using HE detergent? When I accidentally over-sudsed, the LG removed them; it has a special protocol for this. Isn't yours working? It was surprising and illuminating to watch.
And no I wasn't wrong. My hot water is indeed 120-130 as mentioned in the vid because my cold water line is attached to the laundry sink's faucet facilitating any temperature I desire entering through the cold line; thus I don't have to fuss around to get hot water without heating. I think you'd like the Sanitary cycle better than the Allergiene; it's shorter and doesn't use that long initial steam cycle which has set a few stains here that Sanitary then removed. You can upgrade for 12 dollars a year, a buck a month, or 3 &1/3 cents a day. I tried to go without upgrading for health reasons, and it was just too frustrating to do without editing. If you're strapped, the system allows any member to upgrade another member. Would you like me to do that for you? You've been so generous to me here.
Roscoe ~
I have really high water pressure here living on the lake. On some machines, I actually have to adjust the valves toward closed because of all the force, especially the cold water valves on the Frigidaires. The water pressure on the LG seems fine. The incoming water is forced through two "banks" atop the drawer opening. They look exactly like the bottoms of those square shower contraptions on bathtub hoses of old. But loving natural water sports so much, you have me really interested in seeing what will happen to the water pressure if I remove the restrictors, assuming they're there. The machine was installed by the dealer techs, and I have only seen the tap end of the cold hose in which there was no restrictor, as expected. I think you can see the incoming water in the open drawer in the vid, but I'm not sure. Here's Big Wild Cherry's control panel.
