They're Here! My AEG Set Has Arrived
launderess
Jul 22, 2004
20,644
At 1145AM HomeDirect delivered our AEG set and have spent the time since then uncrating just the washer and sorting things out.
Didn't get a chance to take many snaps of the units still wrapped/crated as things got a bit hectic.
Wanted to take some snaps outside where the light is good, and when driver telephoned saying he was on our block got ready to do so; then one went out to the front door/street. Coming towards our front door were the two delivery men pushing a dolly. One crate was on the dolly with another *stacked sideways on top*! Didn't have time to catch the vapors, so shoved the camera in pocket and went to supervise this gig. One had visions of the top stacked sideways loaded appliance (didn't know if it was the washer or dryer) slipping off and crashing to the ground.
Figured better just get the items inside and not fool with these drivers too long. They were nice enough don't get me wrong, but still.
HomeDirect merely double boxed and ply/shrink wrapped each item. No Styrofoam or cushioning especially at the bottom which one requested. So far the washer at least looks fine (haven't unwrapped the dryer yet), and a quick plug in/power on tells me at least the thing isn't DOA.
There was a small black plastic bit at the bottom of the washer crate which had me worried. Did these guys damage my washer? A quick call to AEG in Canada determined the thing most likely was one of the plugs used to close off the bolt holes after removing the transit bolts. After doing so pushed the thing in and yes, it fit exactly so that is that. Maybe the thing somehow was shoved inside the washer and worked it's way out during transport.
There may be a minor issue with the bottom kick plate, not sure if it is damage or just not seated properly. Will investigate further after leveling the washer and taking it off the appliance rollers.
Cannot test fully as one ordered some 2.5m drain and filling hoses from Europe that have not arrived. Also ordered hose joiners so the drain hose can be coupled to make one long enough to reach the sink. If one has the strength and time later will unpack the dryer which is where we think our "Secret Squirrel" placed the original drain hose and clamp. Once they are in place will do a test spin to see if all is well with the suspension and so forth. Just don't want anything to come gurgling out onto the floor.
Think am going to take a wee nap. Unpacking and shifting appliances all afternoon has left me quite knackered.
C.
Thanks
Found manuals on Electrolux's AEG site whist researching the units prior to nabbing. AEG Canada also sent same as PDF via email after application so am good there as well. Printed both out and have been reading and at least for the washer doing some programming (fine rinse, cool suds, fluff after cycle ends, etc...)
Until the weather becomes cooler and dryer won't be using the dryer so there's me for you.
First Impressions
Build quality wise the AEG isn't a patch on the Miele W1070. Far more plastic and fitted bits on the former as opposed to the latter. Not sure if this can be attributed to differences caused by being made in different decades.
One thing one noticed straight away is that the AEG is *quiet* nearly silent when compared to the Miele. No pump noise and so froth. Even on the spin you can barely hear anything. Only tested at 1200rpms, so don't know how silent the AEG will be at the max spin speed of 1800rpms.
Despite being both rated 5kg, the AEG tub seems larger than the Miele. Will have to test by filling an average load in both to see if this is true.
Wonderful
Whilst looks aren't everything, I dare say they add such a functional aspect to this machine. The lighted controls are very convenient for the common dark and dingy basement laundry, and make the machine prettier in the night/during operation.
Really hope this machine gives you good service :-)
All the best!
In Theory
From what one has gleaned from the owner's manual "Moisture Remaining %" indicated how much water *should* remain in the wash using the set spin speed. One supposes this information comes in handy when using tumble dryers especially AEG's matching LavaTherm units. The owner's manual for my dryer breaks down average drying times for loads based upon the final spin speed of the wash.
If you alter the final spin speed the moisture remaining number changes as well.
