They're Here! My AEG Set Has Arrived
launderess
Jul 22, 2004
20,862
At 1145AM HomeDirect delivered our AEG set and have spent the time since then uncrating just the washer and sorting things out.
Didn't get a chance to take many snaps of the units still wrapped/crated as things got a bit hectic.
Wanted to take some snaps outside where the light is good, and when driver telephoned saying he was on our block got ready to do so; then one went out to the front door/street. Coming towards our front door were the two delivery men pushing a dolly. One crate was on the dolly with another *stacked sideways on top*! Didn't have time to catch the vapors, so shoved the camera in pocket and went to supervise this gig. One had visions of the top stacked sideways loaded appliance (didn't know if it was the washer or dryer) slipping off and crashing to the ground.
Figured better just get the items inside and not fool with these drivers too long. They were nice enough don't get me wrong, but still.
HomeDirect merely double boxed and ply/shrink wrapped each item. No Styrofoam or cushioning especially at the bottom which one requested. So far the washer at least looks fine (haven't unwrapped the dryer yet), and a quick plug in/power on tells me at least the thing isn't DOA.
There was a small black plastic bit at the bottom of the washer crate which had me worried. Did these guys damage my washer? A quick call to AEG in Canada determined the thing most likely was one of the plugs used to close off the bolt holes after removing the transit bolts. After doing so pushed the thing in and yes, it fit exactly so that is that. Maybe the thing somehow was shoved inside the washer and worked it's way out during transport.
There may be a minor issue with the bottom kick plate, not sure if it is damage or just not seated properly. Will investigate further after leveling the washer and taking it off the appliance rollers.
Cannot test fully as one ordered some 2.5m drain and filling hoses from Europe that have not arrived. Also ordered hose joiners so the drain hose can be coupled to make one long enough to reach the sink. If one has the strength and time later will unpack the dryer which is where we think our "Secret Squirrel" placed the original drain hose and clamp. Once they are in place will do a test spin to see if all is well with the suspension and so forth. Just don't want anything to come gurgling out onto the floor.
Think am going to take a wee nap. Unpacking and shifting appliances all afternoon has left me quite knackered.
C.
So Far So Good,
No real apparent damage save what might be a few niggles, will have to compare photos taken before shipment and afterwards to confirm.
Will be pestering those with previous experience with these units for tips, so stay tuned to this Bat Channel! *LOL*
Thanks
Found manuals on Electrolux's AEG site whist researching the units prior to nabbing. AEG Canada also sent same as PDF via email after application so am good there as well. Printed both out and have been reading and at least for the washer doing some programming (fine rinse, cool suds, fluff after cycle ends, etc...)
Until the weather becomes cooler and dryer won't be using the dryer so there's me for you.
YAY Launderess!
Happy to hear they arrrived unscathed!
I look forward to seeing snaps and hearing how they work, how you like them, etc
Your secret squirrel
First Impressions
Build quality wise the AEG isn't a patch on the Miele W1070. Far more plastic and fitted bits on the former as opposed to the latter. Not sure if this can be attributed to differences caused by being made in different decades.
One thing one noticed straight away is that the AEG is *quiet* nearly silent when compared to the Miele. No pump noise and so froth. Even on the spin you can barely hear anything. Only tested at 1200rpms, so don't know how silent the AEG will be at the max spin speed of 1800rpms.
Despite being both rated 5kg, the AEG tub seems larger than the Miele. Will have to test by filling an average load in both to see if this is true.
Wonderful
Whilst looks aren't everything, I dare say they add such a functional aspect to this machine. The lighted controls are very convenient for the common dark and dingy basement laundry, and make the machine prettier in the night/during operation.
Really hope this machine gives you good service :-)
All the best!
In Theory
From what one has gleaned from the owner's manual "Moisture Remaining %" indicated how much water *should* remain in the wash using the set spin speed. One supposes this information comes in handy when using tumble dryers especially AEG's matching LavaTherm units. The owner's manual for my dryer breaks down average drying times for loads based upon the final spin speed of the wash.
If you alter the final spin speed the moisture remaining number changes as well.
According To The Manual
Fashion cycle is for items made from man-made fibers such as rayon or Lyocell. Wash temp is set at 40c with a "more gentle wash action than Delicates", but more through cleaning than handwash cycles.
What all that palaver actually means is anyone' guess. LOL
Am Not Feeling The Love ATM - How Do You Level This Thing?
Manual states the rear left foot is spring loaded and should rest firmly on floor. That bit checks out fine. However the other three feet seem to be "loose" or whatever as one cannot screw them up or down to adjust.
All Good Things Must Come To An End
To get a better look at what is going on raised the washer on the right side using a heavy case for support. One flashlight view and the source of my leveling woes became clear; the two right side supports (front and rear rear) that the legs screw into are busted. This explains why the things won't screw up or down and feel wobbly and loose.
The left front leg seems fine, and it's support is intact. Same for the left side spring loaded self-leveling leg. Am going to put a call into AEG's tech support tomorrow to see what can be done. Know it is possible to purchase new feet, but the supports may be another matter. After all they are attached somehow to the washer.
Oh well, at least got the drain hose fitted and tested the unit so far as that goes. No leeks and everything works fine. Mine you only allow the unit to fill, run for a bit, then drain. It was mainly to test if the extended hose was joined properly.
Have sent Mr. Burton over at HomeDirect an email to get the damage claim ball rolling, we shall where things go from here.
Oh, crap. You just can't depend on shippers to move things the way you would move them yourself.
I'm sure if there's a way of rectifying the damage and getting compensation you'll get to the bottom of it. It's a shame you have to go to all that trouble, though.
Would love a vid demonstrating the lack af noise....
Ordered parts from AEG Canada and whilst speaking to the service tech he mentioned one of the legs on his unit was busted as well. What did he do? Shoved a square of hard wood underneath the damaged foot and kept on keeping on. Rather shocked a service person would do this but apparently the machine was level, stable and otherwise didn't care. As the saying goes; faint heart never won fair maiden, I mean what has one got to loose?
Have some rather thick decent sized rectangle shaped marble bits from another product lying around so; up went the washer and carefully slid the bits under the damaged legs/corners. Machine is level (according to spirit level)and does not wobble so..... Decided to run a empty "test wash" to at least clean out any built up detergent residue etc...
My thoughts on the AEG?
Compared to Big Berta (Miele W1070) who makes enough loud and strange sounds at times to wake the dead, the AEG is whisper quiet. You only can tell when the pump is engaged by water draining, on the Miele OTHO you *KNOW* that pump is working. Indeed the only sounds one hears is the muted sloshing of water, water entering the machine, etc...
Major difference between Big Berta and Hans der Grosse is during the spin cycle. The latter is almost again whisper quiet, emitting sounds more like one's Pfaff sewing machine motor that what one is used to from the Miele. It appears late or even very late night laundry may be on the cards once more.
More Damage
Thus far have been concentrating most of my efforts and time on the Lavamat, with the Lavatherm dryer sitting shoved off to the side whilst one sorted out some sort of stacking arrangement.
Well today decided to deal with the dryer situation and noticed the knob shown as totally pristine in the snaps taken by my Secret Squirrel, is now marked and a bit smashed. So much for the highly rated and regarded HomeDirect.
Dearest, Gobsmacked!
Is is not the weirdest proverbial bite in the buttocks that both of our machines, your former WP convertible and the Lavamat had their bottoms damaged during shipping. If one were paranoid......etc.
Love or what have you,
Michael.
Hello and congrats to your new set.
You have good machines there. AEG today is just a shadow of its former self. The quality is absolutely nothing compared to what it was years or even decades ago. The brand shares the fate of many other good brands that built good machines in the past. I would never buy a AEG today as they would not survive a few years.
