launderess
At 1145AM HomeDirect delivered our AEG set and have spent the time since then uncrating just the washer and sorting things out.
Didn't get a chance to take many snaps of the units still wrapped/crated as things got a bit hectic.
Wanted to take some snaps outside where the light is good, and when driver telephoned saying he was on our block got ready to do so; then one went out to the front door/street. Coming towards our front door were the two delivery men pushing a dolly. One crate was on the dolly with another *stacked sideways on top*! Didn't have time to catch the vapors, so shoved the camera in pocket and went to supervise this gig. One had visions of the top stacked sideways loaded appliance (didn't know if it was the washer or dryer) slipping off and crashing to the ground.
Figured better just get the items inside and not fool with these drivers too long. They were nice enough don't get me wrong, but still.
HomeDirect merely double boxed and ply/shrink wrapped each item. No Styrofoam or cushioning especially at the bottom which one requested. So far the washer at least looks fine (haven't unwrapped the dryer yet), and a quick plug in/power on tells me at least the thing isn't DOA.
There was a small black plastic bit at the bottom of the washer crate which had me worried. Did these guys damage my washer? A quick call to AEG in Canada determined the thing most likely was one of the plugs used to close off the bolt holes after removing the transit bolts. After doing so pushed the thing in and yes, it fit exactly so that is that. Maybe the thing somehow was shoved inside the washer and worked it's way out during transport.
There may be a minor issue with the bottom kick plate, not sure if it is damage or just not seated properly. Will investigate further after leveling the washer and taking it off the appliance rollers.
Cannot test fully as one ordered some 2.5m drain and filling hoses from Europe that have not arrived. Also ordered hose joiners so the drain hose can be coupled to make one long enough to reach the sink. If one has the strength and time later will unpack the dryer which is where we think our "Secret Squirrel" placed the original drain hose and clamp. Once they are in place will do a test spin to see if all is well with the suspension and so forth. Just don't want anything to come gurgling out onto the floor.
Think am going to take a wee nap. Unpacking and shifting appliances all afternoon has left me quite knackered.
C.
C.
