dustin92
I decided to try a bag of the pods today, I needed detergent but still have enough left in case things went south and either didnt come clean, or smelled hideous, and needed to be rewashed. I was using Tide Free and gentle. I am not entirely sure of my outcome yet, I have been allergic to a couple variations of Tide in the past, so I should know "The rest of the story" tomorrow. I bought the smallest bag of the "Mystic Forest" scent and to be completely honest, they smelled rather hideous in the bag. I threw caution to the wind and started a load (Heavy fabrics) with only my laundry, I dont end up with full loads of anything, and the only whites I have are underwear and a few pairs of socks, so if I have multiple loads, they are sorted by weight instead of color. I started the washer on warm and waited for it to fill, thrn added a pod. It seemed to take a while to melt/ dissolve, even in very warm water with agitation, and when it did dissolve, it was in stages. The white part disappeared, then after a few turnovers I lost track of the orange and blue bits. Anyway, it smelled MUCH better when dissolved, a fairly light "soapy" type smell. Not overpowering or flowery nasty at all. By the end of the wash, it had worked up very little suds, but even a double dose of liquid tide doesnt create much suds in our water, which is rock hard and full of chlorine. I did use a half scoop of generic oxi clean, which goes in every load. After the load had rinsed and spun, there was very little scent left, which was somewhat disappointing, because it was a pleasant smell. I dried them with a bounce sheet and could hardly detect any scent. I cant say much about stain removal because there were none to remove. The next load is ligh fabrics, which was only a medium load in the Speed Queen, and just finished, but I will post a pic of it about halfway through the wash. Again, suds are almost non existant. Has anybody else tried them and what were your results? Which scent did you use and was it good or bad? I have used the purex versin and was unimpressed, and the arm and hammer version and didnt care for them either.
