brisnat81
Well, the Turner from Ebay finally arrived. When it first got here, I couldn't adjust the speed selector from spin to wash. A good soak overnight with some penetrating oil and it was good to go.
The Pump is friction driven and currently frozen solid, so today I'll pull it out and see if I can get it moving again. Otherwise it's amazingly quiet and working as well as the day it was new. The Service manual I have is from 1956, so I assume there were around before then also.
Spin Speed is 450RPM, Agitation is 68 strokes per minute with a 74deg Arc.
Its a 2300watt element that takes 55 minutes to heat to 180degF, it holds 7lbs of clothes and is 10 Gals per fill.
There are no gears whatsoever, it is all done with belts, pulleys and 3 clutches
