Turquoisedude V Inglis - Round 3
turquoisedude
Aug 8, 2007
10,562
Down, but still not out!!
Last week, I got a call from a fellow collector and restorer in Sherbrooke (he's into the pre-50s ranges and refrigerators in a big way) and he let me know that his uncle was moving and had something that was potentially of interest to me.
Well, I grabbed it!
Best of all, it had a rebuilt wide-belt WP transmission. AND, bonus, the damn thing worked! I tested the washer in agitate and spin modes and by golly it worked consistently in both.
Anyone notice something missing here??
Score 5 points if you said "Missing support braces"! Not sure if that was a problem for this machine or not - it was one less thing to mess with when removing the tranny, though!
Phil helped me with the removal of the bad transmission from the Inglis and helped me reinstall the 'new' WP donor one.
The reassembly went fine and yes, we used the Inglis support braces. The first test was encouraging - the washer actually agitated. But.... it wasn't spinning. The service documentation I have suggested lowering the transmission mounting bolts and retightening. It helped and we got the machine to spin... kinda...
What we also noticed was this:
That brake drum looks 'crooked' as it turns. What could be causing this and what could we do to remedy it?
I'm sooooo close to getting this dang machine running again...
The "Sterling" in the background...
Hi Paul ... that Inglis "Sterling" model looks very similar to my mom's mid-1960s "Liberator". The same graphic on the panel, but that of the "Sterling" appears to be glass - lighting up, perhaps? You didn't take that one as well?
Hi Brad - actually the Inglis Sterling you see in the background is the machine that I've been working on for what seems like eternity... The photo was taken in my laundry room in Ogden! The Sterling washer also has a light-up control panel AND I have the matching dryer that I also need to do some work on (assuming I can get the **multiple expletives deleted** washer running again!).
That spinning video is with all the transmission bolts loosened. If they're tight, the tub brake stay engaged and the spin clutch slips.
I assume that's because of the wobbly clutches. We didn't try to readjust the nut for the brake yoke adjustment.
Brake springs---
At the end of your video when the spinning stops, it looks like the brake springs are at an angle. I think the the upper and lower brake hub is off by 1 tooth on the spline. When you reassemble the brake you must be sure the set screw is fully seated in the spin tube hole, you can put your finger into the spin tube and feel the end of the screw come thru the hole. I also noticed the wires to the control solinoids are not installed correctly, they must come thru the hole in top of the bracket then connect to the solinoids. The way it is you will have broken wires soon.
Jeff, we didn't touch the set screw on the spin tube hole. Just got the whole transmission out of a machine to install in this one. I think I saw the screw you're talking about (same kind of hex screw that holds a pulley on a motor shaft?). If i understand correctly, we just have to make sure it goes through a hole in the spin shaft?
The tub wasn't spinning at all before I loosened the 3 screws that hold it in place (as well as the brackets that were omitted by someone who previously repaired the machine).
If someone has a picture showing how the wires should go to the wigwag solenoids. That might help us! Maybe Paul knows exactly what you're talking about but I don't! I didn't disconnect or reconnect them so... I know they were passing through two round metal clips attached to the baseplate of the newer Whirlpool machine but I see just one on the Inglis.
poor Spinning BD WP
The wig-wag wires go through a hole in the top bracket of the WW assembly directly above the shaft it is attached to, by having the wires centered better it allows them to flex as the WW moves to reduce the chance of wire breakage.
Now that machine spins somewhat with the transmission bolts slightly loosened go ahead and tighten the three 9/16" bolts and see if it works [ you do not have to tighten all the brace bolts for this test ] once these bolts are tight check to see if you have the 1/16" clearance between the top of the clutch pulley and the clutch pads with the clutch disengaged, if not adjust the nut on the clutch control shaft, [ this is the rod that the spin cam-bar slides through ].
If this does not work something else is broken or not assembled correctly and unfortunately you will have to take it apart again, or fly me to Canada, LOL
Hope this helps John L.
Breaking news....
and it's good news! It looks like the Inglis is, in fact, running again!!
I need to do some more tests, but I think I've done it! The Inglis seems to be running normally now with its 'new' transmission! Details, pictures, and hopefully video to follow. In the meantime, the following bulletin was apparently dispatched via local radio station...
"Residents of the Tomifobia valley are reporting hearing loud hollers and a very badly sung parody of the hit show tune 'Everything's Coming Up Roses' echoing through the valley. The only resident along the shores of the Tomifobia river who can access his property for the winter, Yvon Roy, said 'It's probably that damn guy with all the washers working on something'. Louise Bigras, another nearby resident has been quoted as saying, 'Well, if was him, at least he didn't knock the power out THIS time'. More details as this story develops."
So you removed the transmission and replaced the spring you talked to me about the correct position and that did make it work correctly?!
Great!
Yes - I noticed last week that the spring in the middle of this photo was installed below the yoke plate... Boy did I kick myself for that!
Phil, I got lucky and I didn't need to completely remove the transmission as I had thought. I loosened the bolts, removed the support braces, and 'dropped' it just enough to get my shaky, clumsy hands in there.
To be fair, Hubby actually helped me with this by holding the spring down while I slipped the pin at the top of the shaft back into place. And to think, he threatened that this machine would be sent to washer heaven if I couldn't get it fixed this time! I may make a washer fan out of him yet... LOL
With the number of times this poor machine has been tipped over and had it's guts yanked out, I was afraid that the tub seals might have been damaged...
Yay - I was wrong!
Now, I tested the washer at least 10 times last night to make sure it was shifting from agitate to spin and back again consistently. It did so and here's how it looks with water in it! Oh, what a difference a new transmission makes... LOL
