As for fires...
From what I have read (stats), there are a higher number of house fires caused by electrical wiring in the US and Canada than in Europe. Simple reason, it's nothing to do with wiring or standards, it's down to what build your house out of.
In most European houses the wiring is buried in plaster. If it does catch fire, it's not quite so likely to destroy the house.
In a US home, if a circuit overloads, it can be catastrophic due to all the wood in the structure.
In any system, unless you replace the breakers / fuses with over-rated ones, there should be no risk of overloading though.
Also, in the UK/Ireland system, there's an individual fuse in each plug, so you can't overload the outlets either. If you go beyond 13amps, the fuse in the plug melts.
So, if you overload a power strip etc, it's not likely to burn your house down.
I think at the very least there should be overload protection in ALL power strips world wide. It's a very simple precaution and they're a very common cause of fire all over the world!
