nickuk
The online manual for the dishwasher I shall probably purchase states that it is ok to use combination tablets for water up to 26 degrees Clarke. This surpised me. Our water is 19, and known as `hard'. Apparently one just has to switch off the water softener unit.
At the moment I am using seperate powder, rinse aid and salt primarily because I thought I had to use salt anyway in our hard water, but also because I had a preconception that sep. rinse aid would work better. I just don't understand how a tablet which dissolves in the wash water and is pumped away can do anything at all in the final rinse? I used to understand the concept of the little balls inside the tablet filled with rinse aid, apparently they only disolved in a certain ph or something so released into the rinse water. But I think that was Finish, the other combi products don't have that, they are just like regular tablets. Confused.
There is an appeal to just having the simplicity of one product, but there are drawbacks to tablets. The main one for me is how quickly they dissolve, and the obvious issue with quicker, short cycles. I would suspect they would also work out more expensive.
If I were to go for a combi tablet I would probably naturally only go for a cheaper one eg Sainsbugs store brand, as I have said before I have never had much luck with Finish tablets as they oversuds (to be fair to the brand, not so the powder). Infact, I am perplexed as to why Finish tabs are so popular in the UK!! Marketing triumph? Whenever I go past a dishwasher which sounds like it's choking, a quick peek in the cupboard reveals the latest incarnation of Finish `798 in 1 tablets'.
Thoughts?
Nick
Thoughts?
Nick
