WP Built Compact Dryers
These never got very fancy, a few KM versions did get a temperature selector switch, and and 240 volt versions often got a time-temperature auto-dry cycles. The 120 volt dryers did not really need a temperature control as the maximum heat on a 120 volt dryer is not likely to ever damage clothing.
Since the DOE has required all clothes dryers sold in the last 10 years or more to have an auto dry cycle, WP opted to add the electronic sensor system that they use on many of their large to all 120 volt versions of these dryers. This feature can be added to 240 volt and gas versions of this dryer if you are handy and clever. It is also fairly easy to convert the 120 volt versions to 240 volts by changing the heating element and a few other simple wiring modifications.
Note they never made these compact dryers in 110 volts as the US switched to 115 and then to 120 volts long before these dryers were ever made.
The very rare models with the window door are a John & Jeff modification only available at extra cost, LOL.
John L.
