Work begins on the1957 Speed Queen TOL
Magnificient!
The best vid I have seen in a long time. Keep 'em coming!
Long live the Arc-Cuate 210!
Wow!
I think this transmission was a "sludge monster." Those in the Automotive Industry viewing, THAT TRANSMISSION is what your fine engine will look like with extended oil change intervals :P
Still, what a uniquely simple transmission design. It clearly did the laundry, and THEN some.
It also looks like a very efficient, un-wasteful design. The old "Keep it Simple Stupid" rule certainly pays off, I think.
Was this a fluid-driven transmission, or just directly from a clutch and/or belt?
"Solenoid Symphony"
Mom used to let me load the washers. Then I would put in the quarter, (Yes, the Speed Queens were a quarter in 1963) And then I would start the machines in 3 second intervals. When it came to the first spin you heard evenly spaced solenoids engaging.
Do you think I was into it back then ???
Incredible Job on that transmission clean up Jon.
I just talked to Robert about this a few weeks ago while at Don's.  I figured it would require something similar to ATF, or a like Dextron III auto trans fluid, considering the fluid drive does act similar to a torque converter.
Robert had mentioned that he adds zoom spout oil to the drive, and it works well for him.  I wouldn't use anything with a heavy viscosity.
Ben
Jon.....a million thanks for the detailed videos.....sometimes wish trannies had a clear plastic top cover, just to watch them in motion...
Zoom spout oil works best as a replacement for the fluid drive.....but there is a fine line of how much oil is allowed to function, and yet not cause the motor to kick out....
also, these fluid drives can act like a refrigerator compressor, if you lay the machine/fluid drive on its side, it may take a day for the oil to settle for it to operate correctly.....just keep that in mind....
I will check my service manuals for any indication of weight of oil, and how much equals full...I will get back to you....
man, how I wish I could be there to witness all of this rebuild....but these pics and vids are the next best thing...
Transmission Oil
Hi Jon
Great teardown and rebuild: not sure if this helps, but my Simpson Fluid Drive manuals (which have the same transmission) specify a 'viscolite H.H.' oil....that's all they say.
I actually have a spare SQ tranny in a box that I had sent out from the US some years ago.
Cheers
Leon
Thats interesting Leon
As, Mobil lists Viscolite HH as being ISO Viscosity 460 !
Equivalent to Shell Vitrea 460.
Thats a high viscosity, I wonder what the viscosity of Dexron is ?
After more reading I see ISO 460 is about the same as SAE 95 oil. Gear oils are typically 90 wgt. so its a little heavier than gear oil.
Leon I found this is the closest to your Viscolite HH, I don't need a whole gallon of the stuff so am searching for a quart.
[this post was last edited: 6/6/2014-21:24]
jetcone...
thank you for those 2 short videos showing how the transmission works. i really appreciated & enjoyed the handpowered demonstration, showing the workings/movings of the transmission. and it answer a longtime question of mine; how does the agitator move back & forth if a motor only spins in one direction.
and now thanks to you, i got to see it happening first hand with your video.
so, THANK YOU for the videos.
maybe it's cuz i'm mechanically challenged, but i never could imagine how the motor's one direction motion, could cause a 2-way, back & forth motion. and now i see.
:o)
question.....
how does the control panel work on this speed queen washer?? like how do you select a hot, warm, or cold wash and a warm, or cold rinse, and so forth?? the controls knobs have me confused. so please be sure to show a video of how the knobs on the control panel work. ok???
i'll be coming back to see.....
thank you jetcone
:o)
Your welcome
Hippiedoll
That's one of the reasons I post specific restoration information here.  I like you in younger days also was puzzled until I tore down my first transmission.
I have been reading doctrine at night and this machine gets more fascinating the more I read. I found out the TIME button has two settings one is a long wash 11-4 where the machine starts agitation 1 minute before full fill and the bottom 7-2 minutes is a shortened wash where the machine starts agitation 3 minutes or thereabouts after full fill and then !!!! it stops and soaks in the MIDDLE of the wash cycle then starts agitation again for 1 minute before spin!
Also I learned that ALL the cabinet panels come off this machine easily and independently !
It is an amazing piece of engineering!
Also the fluid drive was also used on the Doodlebug Scooter in WWII for getting around with the gas rationing.
[this post was last edited: 6/6/2014-21:26]
Your welcome
Hippiedoll
I have been reading doctrine at night and this machine gets more fascinating the more I read. I found out the TIME button has two settings one is a long wash 11-7 where the machine starts agitation 1 minute before full fill and the bottom 7-2 minutes is a shortened wash where the machine starts agitation 3 minutes or thereabouts after full fill and then !!!! it stops and soaks in the MIDDLE of the wash cycle then starts agitation again for 1 minute before spin!
What an awesome SQ Pair Jon!
The control panels look new!!
Thanks for the Fun Videos!
The SQ "Arcurate" transmission mechanism is simpler than what I originally imagined!Like the way the device works-Just a lever and a few gears!Keep such a device properly lubed and it should work almost indefinenetly.I think a device such as this will outlast the modern designs we see today-and this older one can be fixed!!!
oddly enough, they could have made that tranny shorter, not that space was an issue inside the machine, but seems like a lot of wasted space in the middle of the transmission...
still...a very simple design compared to most
