1893 General Electric Luminous Radiator
David,
I think that is probably 250 watts per bulb, not 250 Amps.
250 Amps would be 25,000 watts at 100 volts. At that rate you probably wouldn't even want to be in the same room when one of those bulbs was powered up!
The second "option" would require ballast circuit and ignitor for Hi Pressure Sodium lamps.The Hi pressure Sodium lamp is most efficent in putting out LIGHT not heat.This would turn the heater into a very efficent light fixture.
