An Unusual Find...Vintage Kenmore Range Hood
Louie, it's looking good. It's not easy to just paint lettering without masking it off. But it looks good anyways.
One more question - this is 42" and your space is 44"? So your vent is really an inch over the edge of your stove if it's a 40 inch Caloric, right? If so, once you get this completed, could you take a photo of the stove and hood face-on, too? (if you have room in your kitchen). Nice job.
Louie
You can do the lettering with an ink roller (brayer). They are available in varying widths. I use them to restore vintage license plates. Even though the lettering you need to do is much smaller the principle would be the same. You don't want the paint too thin or too thick. Don't use too much pressure. I don't imagine it would be necessary to make more than one pass to do those letters but if it were let the first coat dry before doing the second.
Thanks Phil! The hood measures 41 3/4" wide. The width of the space above the hood is 44". The range is 36". I could have had a 40" range and still have space left over. Unfortunately, the kitchen is too narrow for me to take a full front on picture. I am hoping to finish the hood tonight.
Wow Ken, thanks! I should had thought of that. Even though the tag looks OK as is, I would had preferred for it to be painted. Now here's the rub. It's been lacquered. Would the ink still adhere to it?
Well the clear lacquer is nothing but a clear paint so I don't see why the paint you would use for the lettering wouldn't stick. To be sure though you could very carefully roughen the surface of the letters with a fine sandpaper.
Scan the lettering. Cut out around the letters. Attach with museum clay(it comes off easily) or use a rubber glue that will come off by rolling your fingers around it. But you could make this mask, use that roller(good idea Ken) and prevent any over-paint around the lettering. It might be more work or difficult in concept, but the idea of making a mask would keep the paint on the letters. Maybe someone else can clarify this idea or come up with another similar. It might be easy to just roll it on, lightly, and remove anything with an artist charcoal paper stumps. Just some ideas. I'm sure you'll get it to work, Louie - and you can always sandpaper the lettering or rough it up with a fine nail file(cheap-o paper ones).
Phil
Charcoal Filters For An Old Restored Range-Hood
Hi Louie, these may be impossible to find for an older hood, but you can usually open up one end and just replace the charcoal granules and they will be as good as new, to really keep these filters effective you need to do this at least once a year and maybe every 3 months.
I give up. No technique I have tried gave me satisfactory results. The problem is those damn letters are so slightly embossed on that aluminum tag, it's virtually impossible to do a neat job. I tried the brayer, a small stamp and a paint pen.  I used different consistencies of ink. I used the lightest touch. Nope. So, that's it, it stays as is.
