hoover1100
"Even the big Mieles don't qualify"
I was under the impression the material used in the outer tubs of the large U.S. Miele's was the same material used to make the hulls of yachts. Can anyone confirm this?
As for rinsing, yes, some modern front loaders don't really rinse well, however, I don't personally feel a single rinse with a spray rinse in a top loader is really effective enough, having seen a number of videos of them on youtube with cloudy rinse water and suds on top has confirmed that to me. They probably do rinse clearer if used more carefully, but I wouldn't call it perfect. I'm sure they leave clothes plenty soft enough and will not aggravate skin irritations, but this is also true of the poorest rinsing front loaders when they are used properly.
As for modern front loaders wearing clothes out faster, well in the dryer the clothes are tumbled for relatively long periods of time, with high temperatures, continuous fast tumbles and no water at all yet no one complains they damage fabrics, despite having to scrape worn off fibres from the lint filter when it's done.
I haven't had clothes damaged by any machine, I use shorter cycles unless clothes are really heavily soiled, but I think the majority of fabric wear happens when clothes are being worn rather than in the washer.
I would put poorer wash results of U.S. front loaders to be down mainly to the fact they try to make them work in the same time as a top loader, but also the fact U.S. detergents are really formulated for top loader use (even the HE ones) and lack of sufficient control over temperature. After 30mins a huge (slightly overloaded) load of thick absorbant cottons and my Mum's Whirlpool may still be topping up with water to soak the load down. In many U.S. front loaders water consumption (per kg of clothes) is about the same, yet on some machines even a heavy duty main wash lasts a mere 15 mins, so when filled like a front loader can be, the load isn't toally soaked down by the end of the wash!
Machines can wash perfectly in the tiny amounts of water they use now, but the wash times have to be increased. Your average Euro wash time has gone fron under an hour in the 80s to over 2 hours in some cases today, due to lower water consumption. This dosen't matter here because of our laundry habits. Where an American may wash say, 7 loads on one day every week, a European would typically put one load on every day of the week, then go out, go to work, go to bed, or just go and do something else, so it really dosen't matter how long a cycle lasts to us on the whole. Also, for less heavily soiled clothes far shorter cycles can be used.
Matt
Matt
