stevet
Backed into a corner?
Warren,
Does your rack have the small plastic shields clipped to the front corners of the rack? These were put there to prevent water from splashing out of the door and running down the side of the machine that forms the area that the door fits into.
That may be your whole problem.
Also, by now, the door gasket is probably pretty dry and you may want to draw the door in tighter when it latches.
This is a simple task,but involves removing the control panel cover and the dioor handle.
If you do that much, you just have to shim out the latch assembly by putting in thin washers one at a time between the latch and the bracket that holds it to the door and reinstalling the screws. Start with one in each corner of the latch and see if that helps. New door gaskets should still be out there.
And yes, there is a pressure switch that controls for overfilling but sometimes the opening in the sump gets clogged up. It is on the left side so you may want to take a Q-tip and clean it out and see if it works better and the leaking stops.
Don't push too hard as you may cause damage. Pretend you are putting the Q-tip into your ear!
Warren,
