Ah, the old Top vs. Bottom,
..ah, ummm, I mean side loading preference. I guess it just depends on your preference. ;-0
Butte, ah, really,
as far as energy standards are, it is not as simple as simply not using as much water.
It costs energy to pump fresh water and treat it and heat it. The faster population grows, and it is, the more water is pumped and this in some places is lowering ground water table levels. In other areas such as LA one is already living on borrowed water. (the Colorado river)
Then there is the treatment of the discharge water. It costs money and energy to treat sewage. In the U.S. it is rather chemical dependant, unfortunately. If your on a Septic system it is preferred not to have large volumes of water drain into it at once. As it can prematurely rush water into the drainage field.
You really can't do much more with small appliances, stoves, micros, vacuums, and periodically used appliances. I can understand the push to make more efficient washing machines. (and A/C units and refrigerators and water heaters). We have come along way with gas furnaces from the days of 50% efficiencies in houses not well insulated. I just installed a 96% efficient gas furnace. There is very little heat going out the exhaust pipe.
As someone mentioned they will gradually push to phase out TLer's. I am guessing that the new Whirlpools are being made with lower grade metal in hopes that they will not last as long. I know they recently changed the drain hose design so that is all one piece from the pump out.?? what ever.
But calm down everyone, there are now over 300 million people in the U.S. and I would think there is probably at least 40 million automatic washers in this our fair land.
Even if our club here of a couple hundred people could get our hands on a mere fraction of those soon to be discarded machines we could, eventually, scrounge, say, 1000 machines or so for each member(shipping and storage not included). not too bad.
Well there are countries where millions of people, I think it is like 1/3 of the worlds total population does not have access to reliable potable running water. Forget about softened, treated for iron and heated.
As much as I like my 6 year old Kenmore TL MOL washer I am definately looking at a FL, but I, like the rest here am hesitant. Old habits die hard. I have never even seen a FL in action.
I guess it is time to come out of the laundry room closet for me. ... so I'm keeping an open mind on the Top vs Bottom, I mean side debate, thing.
