bradfordwhite
I think propane tanks up to 100 lbs are an acceptable risk. If say someone wanted to cook or use a Bar-b-q, or fireplace once in a while.
We obviously have limits on what is acceptable. We don't allow people to buy uranium in easy open packages from the gas stations. We don't allow the easy access to buying mercury in packs of 3 for $10. Nor do we produce Chlorine Triflouride for kids to use in at home chemistry sets (though maybe in the 50s they did).
Leaded gas isn't made anymore.
We change. We improve.
The problem with piped in gas is you potentially have an unlimited supply. With propane, if an empty home sat for say 4 months and had a small leak and it filled the home, it would fill until the tank was empty and then by infiltration that gas would be diluted.
If it were a piped service it would fill and fill until inevitably a fire source ignited the gas and it would explode.
