here we go again again 2
bpetersxx
Jun 6, 2008
1,811
laf in on the banks of the Wabash River
having to deal with the Maytag dryer
Now the calypso washer have a problem
the control console LED and time indicator have problems lighting up
I thought the ribbon cable was loose and needed to be seated
BUT
The socket on the control board is loose
Need advice on how to proceed
Should replace that one board
Both boards
or the whole console entirely
wo9rks fine otherwise except the bleach hose leaks once in a while due to the seal being bad
Calypso, washer, problems
If the socket on the board is loose, you can send it to course centric‘s and have it re-soldered.
I don’t understand why you would replace both boards the whole consul etc. do you have all these parts laying around?
If you have the parts go ahead and replace everything, none of those three parts are still available but you can find good used ones if you want to look around for them
Where the bleach hose attaches to the outer tub they had trouble with leaks. It’s very easy to take it apart clean everything up and use a very good sealant. When you lock it back into the tub, I would use 3M, marine sealant ,
John
thanks John
tinkering with the Maytag in the background
But and it is a big but
I have a bigger problem than this
The Calypso is totally dead
I want to check it so i can use it
and
I pressed the buttons on the console but it will not start at all
None of the buttons will turn it on
So I gotta figure out what happened
update whaqtever 1
sorry about the resurrection of the thread
dead for a bit but finally got it running
worried something is going out on it and cannot fix it so it runs
Especially since it is the only machine that i can wash jeans in it
