I'll post up some photographs, but in Ireland there would be absolutely no way you could put different utilities into the same cabinet like that.
Gas meters, electricity meters and telephone hook-ups are all kept totally separated.
In apartment buildings they usually group all the electricity and gas meters for each block into cabinets usually located outside the building for ease of access and safety.
Each apartment would have its own meter and a sealed fuse.
On modern houses (post 1960s) the gas and power meters are located outside. Electricity meters are usually in a flush-mounted cabinet sunk into the wall of the house. Gas is normally surface mounted and usually either on the house (near the front) or it may also be located behind a garden wall somewhere safe.
They will not allow you to install new meters of either type in-doors unless it's absolutely unavoidable.
In the last decade or so, telephone connections are also made via an exterior locked flush-mounted small cabinet. The idea being the phone company can test the line in the event of a major fault without actually entering your home and can eliminate your internal wiring from any fault check.
Prior to that, the phone wires usually terminated on a little junction box in your hallway or attic and your internal wiring was connected there.
Link below explains how the power company here wires a new housing development: It's quite easy to follow and details (aimed at building contractors)
