Bauknecht is Whirlpool
And, sadly, not the best part of them, either. Look, I am "German", says so right here on my passport. But I was born in Colorado.
Until Whirlpool bought them, Bauknecht was known for good design and ergonomics, but were never, shall we say, the "quality leader" in the German market.
I worked with their sales department and marketing for a few years as a contractor. Yes, quality is improving. But you must not compare them to Miele. Or even LG.
The Frigimores have three operator caused problems and went through a period about 99-00 when some idiot designed in bad bearings.
Models before or after that era are not inherently bad.
The bearing seal is not as tough as it should be. BUT: The spider cracking problem and the bearing failure problem are both tied to the same thing: These machines were originally built for the low-sudsing, no-chlorine bleach European (not talking UK so please don't flame me) market.
If you use HE detergent and don't use Chlorine bleach, they last forever. Too many suds and the bearing will fail. Too much alkalinity and the spider will corrode. The third problem is cultural. Here in Europe, we always leave the tub door open a crack and give the rubber boot a quick wipe. Since stuff is washed in very cold water in the US (our "warm" is 145°F) and folks tend to close the door you quickly get a mold and slime problem. Just run a hot load once a month, add some citric acid to it or use oxygen bleach regularly. Leave the door open, wipe the lip at the front dry (yes, check the drum before you wash, I read about the poor wee kitten) and your FL will run just fine.
The spider is made of aluminum alloy...the tub is stainless steel...there is a reason they put bits of aluminum in Drano...
If if may make a suggesstion. Living with dogs and cats, I have washed a lot of comforters over the years. Yeah, my 7kg LG can do it. But the best results and least wear on such monster loads is at a well run coin laundry. I have also learned to use "duvet covers" on my comforters - those can be washed anywhere and it cuts down on the cat hair over time.
I have timed my mom's 1200rpm Frigimore against her "Frigidaire TL" at 400rpm (typical WW junk). Sure, the TL washed faster. But add in drying time (not to mention the detergent residue you have without an extra rinse or two) and the FL is only 10-15 minutes slower. But cleaner! Less residue! So we need to stop comparing apples and oranges here.
