Miele W1918 Bearings
Photos of Spider Please!
GrahamW,
When you get this torn apart further, can you please take some photos of the Miele Spider on the drum? I'm curious to see if it is much different than just a couple of photos I have found online of other Miele Spiders.
I know it would be appreciated by about 75% of this group if you could take a few photos of it!
Thank you,
Andrew
One bearing out
Andrew, can you be more specific about what photo you would like? I have taken quite a few shots as I progress. Eg: Here's the spider with the outer bearing (#9 in diagram above):
It was relatively easy to pull.
The inner bearing...
The inner bearing, however, is proving more difficult. And, yes, that is a piece of the outer race...
Here's what is left
No amount of Kroil seemed to help with this one. Here's a photo of the inner race... i.e. what is left of the inner drum bearing (#7 in the diagram above). I'll need to wait until tomorrow before I either use a torch to heat it before trying to get my puller on it. Worst case, I'll reach for the die cutter and see if I can't weaken it without hitting the shaft...
Indeed
Indeed, a similar problem. However, I'm not sure I agree with the statement that:
"I had a tech out to look at the machine. He said there was a plate in back of the inner drum that had broken or cracked. Apparently, with the advent of the 19xx series, this part was cast from cheap "pot metal", making it both susceptible to failure and impossible to fix."
I've seen nothing resembling "pot metal" in my W1918 or my W1903. Other than some dried water+bearing grease residue, the cast spider appears to be in perfect shape. In my case, it is most certainly the seal that has failed which lead to the inner bearing failing as shown in the photos above. In my opinion, the time to fix the bearing was way before, "the knocking became a deafening banging and white smoke appeared in the drum during spin."
As far as this being a 10 hr repair, that is probably a bit conservative but not too far off. It has taken me:
Disassembly - 1hr
Hoisting the drum - 1hr (including the time it took me to find and setup my come-along)
Remove the cast spider - 1hr (including 1 failed attempt but not including 24hrs of soaking with Kroil)
Removing the bearings from spider/shaft - 1hr (note that the inner race is not off yet)
A cutter/ball/saw blade on a dremel tool or die grinder can be used to grind away the inner race. An added thing is that vibration of using the tool helps remove the inner race too. Often on bearings I have had the inner race loosen up and be free before one has really cut through the race. One can too just use the die/tool to get a better surface on the race to pull too.
I would try cleaning off that rusty crud and trying Kroil again. Then try a slight heating of just the inner race with a small torch too.
Spiders
Here are a couple of photos of the spider that is actualy attached to the drum itself. There is also the cast X piece that you already took off from the back of the drum. I'm curious to see what your inner tub's spider is made of.
What is the white stuff that that is one the lower image's drum spider by the shaft?
Can you post a higher res image of spider?
I want to see if if is a casting or forging, or machined.
Thanks for posting the above photos. Perhaps I do have a pug metal casting of some sort on the inner tub. We'll see what it looks like when I finally get the bearing race is free and I'll snap a few good photos of it. Given the exploded diagram and the parts list I have, I don't believe that piece is separately available from the drum.
Photos
The photos above I posted are the only resolution I have unfortunately - I found them a while back on a google search. I did email Miele about what my W3033's spider was made from and they advised the following. I don't know if it's the same solid spider in the above photos or not, but I do know it bolts on the same way - a rod clear through each of the drum baffles and a nut on the front of the tub can be seen if you peel back the boot a bit. I would imagine it's the same spider design, since my W3033 is the Generation 2000 chassis design.
In 20 years when mine needs new bearings I'll post photos LOL
Per Miele:
"The bearings for the W 3033 are made of hardened steel. The spider which is on the back of the inner drum is made of a cast metal combination of aluminium and magnesium."
Andrew
Before using a flamed torch I use a hairdryer; or better yet a heat gun for electrical tubing shrinking. Time is your friend in the matter too. ie hide the hammer for awhile and just wicking stuff and heat so the shaft is not ruined in hasty event. If that race is heated with a heat gun it often will open up a tiny gap and the PB nutblaster or Kroil can get down deeper.
If one grabs the inner race with a wrench and tries to turn it a tad; I assume the shaft is in the spider so this might not be a great thing to do. Sometimes in machine work we use to wrap the shaft in rubber then key it in lathes locked chuck to hold the shaft still while a bearing race was tired to be turned and pulled off.
Not yet
"If one grabs the inner race with a wrench and tries to turn it a tad; I assume the shaft is in the spider so this might not be a great thing to do. Sometimes in machine work we use to wrap the shaft in rubber then key it in lathes locked chuck to hold the shaft still while a bearing race was tired to be turned and pulled off."
Miele didn't cheap out on these bearings... After spending an hour, I have 3 deep vertical cuts in the inner race but I'm no further ahead. Tried the puller hoping it would shear apart but no luck. Will try again tomorrow night once the kids are in bed.
I do wish I had a better option to hold the shaft when I tighten down the puller or, as you say, a pipe wrench on the race. A 4-jaw lathe chuck might work if the shaft didn't have an awkward, 100 lb stainless drum assembly attached to it ;)
Dynomite
A stick of TNT might be your next best option :) Keep at it, it'll come apart eventually. Might try a dremel to weaken that race until it finally breaks off. Would be much easier than trying to use anything else that I can think of.
Can you take the front of the outer drum off, and take the drum / spider out of the outer tub? it might give you more room to work on pulling that stubborn bearing off the shaft, and a lot less weight to muscle around with while trying to.
White Deposits On Spider
I too would be interested to know what the ‘white stuff’ at the centre of the spider is. I asked the same question on another thread on this site but received no response. I suspect it is products of corrosion between the aluminium of the spider hub and the alkaline laundry products used. As I have stated before even the fastest spin will not get rid of the ‘water’ in this area and this ‘water’ will evaporate until the concentration of the ‘laundry aids’ remaining reaches a level where corrosion occurs.
It's appart. I decided to remove the inner drum to as I really didn't have clearance to cut the bearing race with the stainless tub so close. I needed to use a pair of shears and cut away the spring seal (# 4 in the diagram) so I could push the shaft through the tub. In the end, I basically needed to split the race to get it off. It took an hour and a half to separate the drum and cut the race but I was careful enough not to hit the shaft so everything looks ok. I'll obviously need new seals, spring clip and bearings to rebuild it. Some photos in the posts that follow.
Another photo
Here's the bearing which shows the swiss-cheese groove I needed to make. A few light hammer taps with a punch and it was free.
I'll clean up the inner drum and post a few better photos of the spider but here's what it looked like when I pulled it.
Seal Landing
I hate to say it but it looks like the brass sleeve for the seal landing is grooved in a couple of places. I doubt that it is supposed to be like that.
As for the deposit on the drum that does not look like the products of corrosion to me. Additionally, it appears that it is the same sort of deposit on the spider. It will be interesting to see what the spider looks like when it is cleaned up.
Thanks, I really appreciate the chance to view the photographs.
Seal landing
On the old fl westinghouse the feature on the shaft that contacts the seal is brass and the shaft is replaceable since the 3 belt only turns one way. Ie the shaft is screwed into the drum. One units that rotate both ways the shaft may not be replaceable. The seals mating surface has to be smooth but often not mirror smooth. Often a worn surface will work if touched up with 400 or 600 paper rotated like shaft rotation. A line on the old shaft is normal. The pickle is if it still is larger than the new seal. Limeys concern is good. Good to see you got the inner race off. You can use stainless steel ball bearings too. I did this with a recent rebuild. Ss ball bearings have a lessor rating maybe 80 to 90 percent of 52100 ball bearing steel. But are more robust for corrosion. The 6205 bb here are used in snow mobiles in stainless thus not too expensive
"I hate to say it but it looks like the brass sleeve for the seal landing is grooved in a couple of places. I doubt that it is supposed to be like that."
I noticed that in the photo as well, but didn't see it when I was in the garage. It might be the camera flash catching the light a little but I take a good look tomorrow when I get a chance to clean it up. From the diagram way up in this thread, I'm wondering if that is part #5? I think I'll put in a call to Miele next week and see if I can talk to someone knowledgable about these machines to confirm what exactly needs to be done to get her working as she should.
Thanks!
Really appreciate the close up photos of the drum spider and shaft. I'd say that the spider looks to be in excellent condition vs some I've seen on other washers that totally crumble from corrosion.
I plan to do a yearly descaling of my Miele and I do monthly maintenance washes to hopefully prevent any buildup on the drum spider. I wonder if possibly that buildup gets in behind the drum seal and causes it to leak into the drum bearings?
Any idea of how many operating hours are on your machine? Not sure if there is a way to check on older Mieles, but mine has 897 hours as of tonight. The main bearings are rated to last at least 20,000 hours, so I'm right on track for 20 year life of this machine. I've had it just over a year now.
Andrew
Scale
To grahamW
I have to agree the seal landing sleeve may be the item show as #5 in the diagram early in the thread. The question that springs to my mind is: “should it be replaceable how on earth are you supposed to be able to get it off the shaft of the spider”. I know it could be ‘turned off’ with a large enough lathe but how many appliance repair techs have that sort of equipment in the back of their van?
I have given the composition of the scale on the inner tub and the spider some more thought and I have come to the conclusion it is likely (not positive at this time) the re-deposition of dissolved salts from the tap water as it (the tap water) evaporates. Any thoughts on this anyone?
".... Back of Trucks.."
This isn't the sort of thing Miele will do in a person's home, not at least in the United States anyway.
Should Miele decide a bearing replacement is required, and will do the work at all, the washer must return to the corporate workshop in New Jersey.
Methinks the only way Miele would do this work is a warranty repair and who knows if even then. Probably would have been less bother simply to give the customer a new washer.
Cost of transporting the unit to and from NJ is about $1500 USD, then one would have to add the costs of parts and labour. When all is said and done you are probably looking at near or over 2500 to 3000 USD.
Being as this may, there seems to be quite allot of bearing replacement work done on all models of front loaders in Europe, even as a DIY project. To be fair those on that side of the pond have had >thirty years of front loaders as the main washing machine. So it is very likely many repairmen have the tools "in back of their truck" or perhaps their own workshop for the job.
With the new 1976 Westinghouse Front load washer bought in 1976, its 6205 bearings started to get noisy about say roughly 2000 ish; ie 24 years of usage. The machine still was used with noisy bearing noise until the one closest to the water seal had it's cage break about a month before Katrina in 2005. The machine actually still would wash but sounded like a wild mess in the spin cycle. If one had to one could wash and rinse and use the clothes line.
The back/rear 6205 ball bearing technically is shot; it has more than the classical 10 percent area on its bearing races pitted. Still that bearing in the rear really was never all rusted either, and really could if one had to be reused if one was on a desert island. The bearings from 1976 are from Japan; NTN bearings.
Thus from a ball bearings purists standpoint one got 24 years until one got bearing noise, and 29 years before an actual failure of the products purpose due to ONE out of two bearings.
"failure" is often based on Harris/Skf's criteria of 10 percent pitting by surface area of the races.
"failure" too can be defined when the device no longer works as designed; like the 29 years and then the front bearings cage started to come apart and some of the balls were not equally spaced.
"failure" can be too by just noise and customers complain. Often a ball bearing can go 10 times longer with being noisy.
The washer is different; the ball bearings once the water seal fails dies 100 time quicker once exposed to open water and soap.
Thus classical ball bearing life almost never gets hit with a washer; the leaky seal cuts it short by 10 to 200 times. The primary failure is corrosion ude to the seal leaking.
Its is like if some health food freaks who never smoked or drinked wanted to live to be 120; but all take up skydiving, playing with sharks; playing in the freeway; going off to war zones without helmets; ie many die much sooner than the "planned 120 years".
The seal's LIFE really is the key; when it fails the ball bearings die radically sooner.
If the seal still is smaller than the shafts "seal surface" the seal can still work. IF the seals matings surface is too rough the new seal will fail quicker; the seals "lips" are worn off. Thus the seal's mating surface really has to be touched up, smoothed. This might be a lost art, eons ago folks rebuilt water pumps in cars and it was super common; yea! in the usa 6 volt car era! :)
I would not even try to get the shaft off or think about it until I had an actual NEW seal to test the shafts seal surface.
What is the material made of that the Miele Seal mates with?
Here are the two 6205 bearings on a 1976 Westy FL washer's shaft.
The water seal bares/mates with the brass feature on the steel shaft 5303261165.
The brass feature is that different colored area at the left of the NEW left 6205 ball bearing.
The ball bearing at the right is the original ball bearing from 1976 that came out of the unit in 2005 and still functioned 29 years later. That is the rear bearing. It has a less harsh life that the front guy. It is farther from the water, it has a lessor load too. it is pampered and is not in a war zone like the ball bearing by the water seal
This actual shaft with its scores on its brass feature was in the unit again from 2006 to 2010 this fall and the new seal of 2006 did not leak. This shaft is not being replaced today; not due to the seal area; but the wear to the right of the right bearing; where the potato pulleys roller bearing mates.
The link shows how the shaft is worn.
***Graham; It is not clear if you Miele's seal "bares" against steel; or is it a brass feature that is all dirty.
http://www.youtube.com/user/3beltwesty#p/u/11/4Lu18jyPy6I
Steel
Poor lighting in the garage have yielded a few misconceptions:
- those groves are machined into the shaft
- there is no brass collet, just the steel shaft
With the above cleared up, after a bit of cleaning I can understand where some of the concerns regarding the spider casting are coming from. I'm going to post a few photos in sequence...
Recall, here is what I started with:
