e2l-arry
Jim, I didn't use
the cork gasket. I bought that by mistake after looking at the parts manual. I didn't notice one gasket was labeled "old" and the other rubber one "new". Apparently the "new' one is designed for the spun aluminum tubs, which I have. And, here's the catch, if installed CORRECTLY does the job!
It only took me about 30 minutes to get the thing apart. After 4 hours yesterday putting it back together.
When I order another set of gaskets I'll ask Phil if he sells the rubber plugs. If not I'll plug it myself. I am convinced that was a big part of the problem. The other, incorrect alignment of the power unit / center plate. NOW I figure it out!
Stan, if you go upstream to the picture where I took out the first tub, on one of those pictures you'll see the rubber gasket laying on the floor under the skirt. I'ts just a big O-ring basically
