Kevin
Will get pics of the machines.insides.. The Dryers do tilt to unload the washers do not. Although they do make washers that tilt also.. for another 20,000.oo These were 95,876.00each anyway.Dryers were 43,500.oo and the flatwork ironer was 237,000. the towel folder was the cheapest @ 42,000
I now manage 2 plants both totally different. One is a shared services facility and the other is a single decitated plant. The capacity on any machine is dryweight. A load out of the washers go directly into the tumbler.
Wash Formulas: there are 15 ranging from lite soil to extra heavy. Drape formula, Uniforms, Kitchen and mops are also done. there are 2 mop formulas as some are standard mops and some are microfiber mops.. both must be done very .differently. On a avg. turnaround time on the washers is 45 mins. And depends entirely on the washman. I leave it up to him as to have a assit. help him unload or unload alone. It all depends on the amount of work that must be done that day.On blankets it always takes two to unload 1 cannot get them out of the machines without killing himself. The dryers avg time in 15 mins including a 3 min cool down and the unload time makes around 18 mins. Most all loads dry in the same amount of time as the washers have a 1200 rpm extract and with the 52" tub ,that is some serious g forces. some of the work does not require drying at all. Curtains go right back to the rooms out of the washers Flatwork goes right to the ironer, mops are so dry they go right back to housekeeping. The times on the General formula are as follows
Flush 3 Min Split hi level 22"
Wash 10 Min Hot lo level 12"
Bleach 10 mins Hot lo level 12"
Carry/Over
Rinse 5 MIN Hot lo level 12
Rinse 2 min cold hi level 22"
Extract lo 1 min
Sour/Soft 5 min split lo level 12
Final extract Hi 6 mins
hope this got most of your questions, if not just ask.. anything you wish.
