New Dream Machine Acquired!
pulsator
Jun 30, 2002
2,373
Saint Joseph, MI
Well, it’s been a dream of mine for 30 years and I finally did it! I have acquired an industrial washing machine! I have vivid memories of watching Wascomat W74s, 35/40lb Milnors, and hard mount Speed Queens at the local laundromats when I was very young. My first job was at the local YMCA washing, drying, and folding towels in a 50lb Dexter machine. Changed jobs to a fancier gym near the end of high school washing towels in bigger 80lb Unimac machines. Even helped them decide on replacement washers after the 80lb machines they had suffered bearing support cracks from chronic overloading. After I graduated college, I started my career at Whirlpool.
When I was laid off from Whirlpool, I was training for a vertical axis cycle design engineer role which gave me the ability to write my own cycles for topload washers. Aside from missing all of the great people I worked with, no longer having access to write my own custom cycles has been a large void for me recently. Getting this machine allows me to have a piece of that back.
I knew that I wanted something that was soft mounted to ease the installation, but I also wanted something that was at least 3.5 cubic feet. The allure of a touch screen was also something that was hard to say no to! Finally, I needed to be able to get the machine through my doorway (less than 29in in width or depth) and down my basement stairs (460lbs!!!). The machine that fit the bill was a Unimac UYT025. It’s 3.7 cubic feet (rated for 25lbs, drum volume of 105 liters).
I was originally told that it would take 12-16 weeks for the machine to arrive. So, I began to plan for the machine’s arrival in January/February. 10 days after the order was placed, I got a call from the shipping company asking if they could deliver my washer in the next 30-45 minutes. Turns out they had one that was built in March at Ripon, WI and I guess the order had been canceled or something, so it was sitting in storage. That caused me to have to kick everything into overdrive a bit and while I ran into many obstacles, which I will get into at some point here, ultimately, the machine is here and I’m just getting it up and running! With the help of my incredible husband and one of my closest friends Lindsey, we got it down to the basement (with a non-zero amount of damage to the doorway…) and it sat there for a week or so while I figured out mounting the riser to the floor, grouting the riser, running power, and getting the drain set up. I ended up buying an electric stair climbing dolly to take it down to the basement (could not have done it without that) and I think that will end up being a great investment for moving other machines as well.
I’ve managed to get everything to come together enough to finally power the machine on and run it empty! The level of joy I felt (despite my very very sore back) was indescribable! I still need to do a lot of finishing touches like putting away my tools (I’m notoriously unorganized and messy lol) and peel the remainder of the protective film off the cabinet. I absolutely cannot wait to get some cycles of my own loaded onto it and continue to share updates, photos, and videos with you all!
This is so cool jamie - congratulations!  I'm so jealous - lol.  I've considered buying a used commercial machine several times but scrapped the idea due to mounting/install, electrical (pesky 3-phase!) and other roadblocks.  i'm so glad you figured out how to overcome all of those obstacles and realize this dream, i can't wait to see some videos.  You look ecstatic, congrats again.
John: to answer some of your questions:
Unimac is the OPL/Industrial division of Alliance. They sell many OPL products that range from SQ FL and TL clones to Large format HM and SM Washer Extractors up to 250# capacity. This machine is available for Laundromat use under the SQ and Huebsch names in a Coin or Card Op format.
This machine can be ordered in a variety of voltage and phase configurations. Anywhere from 120/60/1 to 240/60/3 depending on applications. Overseas voltages will vary of course. It may be available in 480/60/3, I am not sure about that though.
I can't speak to the cost of this Washer/Extractor but I know it is worth several thousand dollars before delivery and installation.
WK78
Thanks for the kind words! I feel so fortunate and am incredibly excited to have this machine!
This particular machine is wired for 240V. It has an internal 3 phase converter.
If I did not use the 8 inch riser, the machine would not require bolting to the floor at all. It comes with some very large feet. But since I wanted the riser, I did need to anchor it but the anchors don’t seem to need to be able to deal with anywhere near the amount of stress that a hard mount would transfer to the floor. In addition to anchoring, I needed to use precision grout underneath the riser to allow full contact between the riser and the floor to spread out the forces.
Yes, Unimac is part of Alliance Laundry. This particular machine was made in the Czech Republic which makes it a Primus design I believe…
In terms of price, yes, very very expensive! Think high 4 digits.
Seems I am making adjustments to and downloading cycle updates pretty much after every load. There are a few quirks that I have to work around or figure out how to solve and what causes them. For example, there are 2 types of spins you can select for intermediate spins after a water bath. Spin or Soft Spin. Spin takes off quickly like you’d picture a hard mount machine doing. Soft Spin accelerates slowly, I’m guessing for larger/more absorbent loads like towels or blankets to prevent water/suds lock. I use Spin for the most part but when I download cycles that I’ve made on the computer, it seems to default to Soft Spin despite what I selected. If I program it on the UI directly, it will use whichever spin type I selected.
Spending some time learning it and figuring out the settings I like, once I get to a reasonable point, I will get some videos recorded and posted! I also need to finish removing the protective film, put my tools away, and just generally clean up the area…
Looking forward to sharing more as I go! So far, I am very happy with this machine!
WOW! So impressive! As a nerdy kid and teen, I often wondered what it would be like to have an "all you can load" machine like this for home use. Of course a laundromat-type ginormous dryer would complete the set.
" For example, there are 2 types of spins you can select for intermediate spins after a water bath. Spin or Soft Spin. Spin takes off quickly like you’d picture a hard mount machine doing. Soft Spin accelerates slowly, I’m guessing for larger/more absorbent loads like towels or blankets to prevent water/suds lock. "
With machines that have pumps yes, there is risk of suds lock or otherwise overwhelming pump with more water/froth than can handled when machine goes into hard spin. Hence reason for "soft" spinning. However such things can (or could) be overcome with programming same as with domestic washing machines long have done.
On other side of things there is the long standing (and still raging) debate on how much if any extraction should take place between wash and first few or all rinses.
Purists cling to old ways that existed before "washers" became "washer/extractors". That is laundry is simply rinsed, rinsed, and rinsed then after final rinse extracted. These persons feel extracting after wash "pulls" soils and muck through wash thus textiles will act as a strainer of sorts.
SQ front loaders (hard mount) at local laundromat do soft spins after first few rinses then finally a hard and fast one just before final rinse. Those machines have dump valves and troughs thus aren't bothered about water/froth coming in large amounts at once.
Drier wash is after extraction means it will take up more water for subsequent rinse baths. Depending upon who one looks at things this can be good or bad.
Soft spins can be seen as meeting things in middle. Extraction is enough to sling good bit of water/muck out of wash, but things aren't so dry load will take up full amount of water in subsequent fills.
Drier wash is also means it may take time for wash to reach full fill water level. This is due to washer perhaps having to stop and add water as it senses level has dropped because textiles keep absorbing water until they are fully saturated.
Milnor is flogging "Rinse Save" feature on their OPL/Industrial/Commercial h-axis washers. Basically feature incorporates extraction after main wash and subsequent rinses. This eliminates (so Milnor says) one or two rinse cycles which in turn saves water and time.
Think of all the possibilities laundry chemical wise Jamie!
You can now use all those Ecolab products including that fabric softener you've long loved.
Ecolab or other chemical suppliers likely won't reveal programming/dosage, but much of the dispensing equipment both NOS or used is on fleaPay and other places. That and of course the products themselves.
These machines will hold huge amounts of wash and will do so very well at rated capacity. That is if thing is rated to wash 40lbs of terry toweling, that's what it will do.
Maybe consider obtaining some sort of laundry or whatever scale so can weigh loads.
Few years ago Unimac held a contest to find oldest units still in operation. Zengeler Cleaners in Chicago, IL. won with Unimac units installed over 35 years ago. Units are still working daily and haven't missed a beat.
Rinso, I wish I could get a matching dryer! Alas, those are just too big to fit through my doorway! Maybe someday when we move into a different house.
WK78, thank you! I am very excited to have been able to accommodate this machine! I will definitely be planning to share pictures/videos as I begin to dial in some good cycles!
Launderess, there are similar machines under the other brands like Huebsch and Speed Queen however those models were not available in an OPL version with the color touch screen. (At least in the US that I could find.) The hard mount variants are completely different animals and are designed and built in Ripon, WI.
The cycles that came on the machine were not to my liking. I’m definitely of the “spin after each bath is required” camp. Seems Alliance disagrees. So, all those cycles were promptly deleted. (Okay okay, really more like they were accidentally deleted… Oh well, I don’t miss them lol)
Incredibly good memory on the Ecolab softener! That’s something I might consider. But for now, I think I’ll stick to residential chemicals! I do plan on looking into getting some peristaltic pumps to pump liquid detergent and possibly some of the Downy Rinse and Refresh (essentially a residential laundry sour) as this machine does have chemical supply signaling capabilities.
Mark, I absolutely plan on filming and posting many videos!
Congrats!
I occasionally have the bug to find and install an old Speed Queen SC27 240/1 phase washer but everything fits in the Maytags so it's hard to justify.
Honestly with me I would absolutely love to find
A speed queen super 20 to have in my collection, sure it’s a bolt down beast, but it would probably be fun to use as it’s old enough. It doesn’t have a dispensing section. And if I ever get my hands on one, I’m gonna make sure it’s in avocado green.
