Brent-Aucoin
- Joined
- Sep 4, 2004
- Messages
- 887
Well, I was on Craigslist today at work, and I saw an ad for a free Stainless Steel Kitchenaid dishwasher, 2 years old, come pick it up. I thought what the heck, it is on the way home, and I could play with it and see what the newer Kitchenaid is made of.
Nice married couple just bought a home, and they are redoing the kitchen.
I loooked at it and decided that this model is still on the floor at Lowes and other places. I was able to pick it up myself and load it in the wagon.
It is a Kitchenaid KUD101TJWHO, or something like that.
Well, I hooked it up in the garage, and could not get over how quiet it was. I then decided to open it up and trick the switch, and watch it in motion. I could not get over what I saw. To sum it up...a child could uriniate with harder pressure than this dishwasher! I could not get over what I was seeing! Every spot of the dishwasher was being hit with water, but it was like a nice summer drizzle! You don't need a demo glass with this one folks! You can just run it with the door open! I am serious!
I then drained it, and turned it on it's side to examine the bottom of the washer. I can say that I don't see how this machine passes for saftey! I am stunned at how it is all put together. The entire "sump" that contains the motor for washing, and the drain pump is all connected together. There is three pull clips that come out so easy. When you pull these baby clips out, the entire sump falls out! I could not get over this. After looking at this even more, I could not get over all of the "gutters" around electrical parts. Main wash motor, drain pump, and such have this "gutter" to drip the water away when there is a leak. I decided to fill it up and let it run, and see what I could see. No leaks. Wow! Then I started to just barely push on the "sump" housing, and water started coming from everywhere!
Are all of the Kitchenaid dishwasher built like this now? Even the high line $1,400 machines?
I am still stunned! I would not even give this machine away for use for the fact that I would be scared that this sump would leak, and shock someone, or flood their home.
Has anyone else noticed this junk?
Brent
Brent
