Ralph,
That photo is from the text link I posted. It's not of the components from my '50 Plymouth radio.
And the "Black Beauty" does not look familiar anyway. I do recall replacing the vibrator that hiked 6 volt positive ground to whatever higher frequency voltage the radio itself needed. That was relatively easy and worked just fine. In any case, I replaced ALL the capacitors so if there was a defective one in there, it's long gone.
No, the problem I encountered was with the square or rectangular caps, the ones with three dots or six dots. I simply couldn't find any explanation of how to read the dots; the electronics store was no help, so I took a best guess. The radio works but the volume isn't what I think it should be, and the reception could be better, too. So my suspicion is that the performance has been affected by capacitors with the wrong ... capacitance. Once I know what the values should be, it would be a relatively easy process to replace what I put in there in the mid-90's with the correct values.
