2011 energy compliant washer
This design tweak on the infamous DD washer owes its thanks to the U.S. energy standards set fourth for 2011.
The previous 2009/2010 Estate, Admiral, Inglis, and yes Roper machines, had four old-fashioned water levels. The same models were re-tweaked with the modified 3-level settings using a pressure switch that doesn't fully fill the tub for wash.
Its funny, but I've heard that many consumers complain about these, and some in fact write about splashy low water rinses in online reviews, but are too stupid to see the color printed instruction under the lid, either when they buy the machine or when it is in service.
The U.S. government says a washer should use only a certain number of gallons, etc and this is how WP made the low-end DD machines comply. Without these the company fails its energy complaince (and tax status).
There are a couple simple solutions, one of which WP does not want us to know about apparently. FIRST, the second pressure switch (yes Tim, there is a second pressure switch for the rinse, which is buried in the console) is a two setting switch, but the shaft for turning it is not long enough to protrude into the console. The switch can simply be re-set to the high setting and the machine will fill to high for ALL rinses. SOMEONE TRY THAT!!!
Secondly, I've heard that a jumper wire or set of jumpers is possible at the timer quick connect block. I have no proof of this however as I have not seen the wiring harness, but it seems reasonable.
My solution, and I actually considered buying an Admiral when Home Depot had them on sale for $249 recently, is to disconnect the rinse switch and jump the wiring over to the wash switch, which would give variable rinses.
Couple my solution with a new pressure switch from 2009's Whirlpool WTW5100XQ and you'd have a properly filled 3-level machine again.
I still say it would be fun to buy one of these and modify it into a PROPER washer.
Gordon
Gordon
