But what about the bolts that go through the SS drum into the aluminum spider ?
You are correct Greg, just putting a plastic washer between the two different metals does little good, there are ways to use special fasteners to do this but it affects the strength of the assembly.
Painting or coating of the aluminum would likley do very good as well, when washers had pot-metal aluminum water pumps manufactures tried different epoxy coatings etc and they did as much harm as good, because moisture would get under the coating and corrode even more quickly.
Greg I would be willing to bet when you do an autopsy on your 20+ YO Asko some day that the spider will look close to new.
John L.
John L.
