Tide Pod Stains A Load Of Whites
frigilux
Mar 3, 2007
12,661
The Minnesota Prairie
As mentioned in other threads, I decided to force a Tide pod to malfunction, creating stains and, hopefully, an undissolved casing.
To accomplish this, I double-wrapped a pod in towels, then placed the bundle in the center of a maximum capacity load of white bath linens. The load was washed in cold water on the Quick cycle with the soil selector set at Extra Light.
Step 1: The pod is placed in the center of a flour-sack dish towel.
Step 4: The small bath towel is folded around the pod towel. The bundle is placed in the center of a full load of bath linens.
Note: I filled the tub to capacity with more towels, but the photo of the full load was very blurry, so I didn't include it.[this post was last edited: 4/18/2014-11:04]
Here's a better photo of the slimy, very sticky undissolved pod.
Next up:
Step 1: I'm going to re-wash one of the towels while it's still damp, using warm water and another Tide pod. Had this happened to a load of dress shirts (God forbid!), I wouldn't be able to wash in hot water or use chlorine bleach.
Step 2: I'll wash the stained hand towel (which is one of my good ones) in a small load of kitchen and personal whites, using hot water, liquid chlorine bleach, and the Sanitize cycle.
Step 3: The dish towel will be dried in the dryer, mimicking what would happen if a the stain had been missed coming out of the washer, then dried. Then I'll wash that with a load of kitchen whites Sunday or Monday.
I'd like to reattach the pod casing to the dish towel, then dry it. I've read that, when heated, the pod casing turns to hard plastic which is extremely difficult to remove without tearing the fabric. However...I do not want to risk the casing attaching itself to the interior of the dryer and forming a bond with the drum or one of the paddles. Sorry, kids!
We'll see which, if any, of these pod stains are removed.
Nice test!
Good thing my washer doesn't even have a cold setting.
I suppoese, you could also just rinse a bit of the towel under warm water and see if that removes the dye. Instead of the dryer, why not use your hair dryer (if you have one).
Alex
Fascinating, Eugene!
This underscores a lot of what I had been suspecting--that the people afflicted with this staining phenomenon are stuffing the washer, running it on cold/fast washes (damp laundry equals finished), and/or any combination of the above. Your approach is clever and is a nifty way of simulating those conditions.
Rather than manufacturers needing to revamp their products, I suspect we have a lot of folks in this country who need a first or even second pass at Home Ec. :-)
Mr. Impatient: I threw the heavily-stained dish towel and the stained bath towel into the dryer. Since the blue stains on the damp hand towel were removed in warm water, I decided to rewash the dried items in the same manner. All stains removed! No hot water or liquid chlorine bleach required.
Here's a photo of the dish towel.
Pondering: Why did the small chamber of blue liquid stain numerous so heavily, while stains from the same-sized chamber of orange liquid are very light and only on the dish towel pictured up-thread? [this post was last edited: 4/18/2014-17:50]
What
is the blue coloring for?
With that much blue color.. If you wash a yellow shirt, dose it turn the shirt green?
Why dose the "blue" have to be there in the first place?
What is the plastic material that's holding the pod thing together? And where dose the plastic, or whatever it's is, go after it dissolves?
I don't get it
Those stains...
Specifically the Purple one, comes out with lots & lots of rinsing, under cool *not cold nor warm* but cool water. Tide also recommends, the use of a cotton swab and rubbing alcohol to remove any remnants that remain after thorough rinsing, along with another wash, with a liquid or powder (non pod) detergent, preferablly long if the clothing fibers can stand it.
On another note.. I must say those are some fine linens you have :) They look quite nice.
Whoops! Your eagle eyes probably noticed that I posted the wrong photo in Post #750977. Instead of a repeat of the hand towel, it should have been a photo of the now clean, formerly heavily-stained dish towel. Fortunately, the correct snap was still in iPhoto.
