At first I thought it was a fluke, simple timer specification error or water evacuation miscalculation on my Speed Queen. Then again I did turn up the water level on my machine, so maybe they were taking that into account the tub being only 2/3 full. So it would make sense why my machine always starts spraying water while the tub is about 1/3 full of water. Ok, makes sense. Kind of, but good enough.
However, looking at timer model, electronic, TC-5 and even TR machine the spray rinse always begins with the tub about 1/4 full of water. In fact when all variable are taken into account, it seems like Speed Queen deliberately programmed their machine to add water at exactly the point the tub dips to 1/5 water. This holds true for all cycles, including normal eco.
My question is why? Why not let the machine reach full spin speed and then do a 30 second spray rinse? Whilrpool, GE, Frigidaire, Maytag, ect all let the pump first start pulling in air even worse case scenario.
36:52 is a perfect example:
Ok, I get it, water was added to the tub and its only rags. 7:44, correct water level for the water, same thing:
15:28:
I can post 100+ videos of this exact same phenomenon in 12 different models over a 25 year production period.
My question is why? What benefit does it serve when the water doesn't even go through the clothes?
It gets weirder in that the tech sheets and service manuals relevant to timer models actually list the spray starting in the second increment or 3 minutes in yet all real life scenarios put the spray in the first increment at about 1 minute out from the start of the drain.
Is someone at Speed Queen making last minute changes behind the backs of engineers? I don't think a spray rinse should start so early.
15:28:
