Why Has Whirlpool Never Sold a BOL Power Clean Module?
Do you have quantifiable evidence, or is your statement speculative?
Even our cheap dishwashers here will perform well without pre rinsing, and I find it difficult to believe that American dishwashers can’t do this.
Based on what I've seen in person, heard in person, and all the internet talk of poor cleaning and stinky filters over the last 20 years.
I literally had a friend who went tall tub and the spray arm holes started clogging. People at Sears in the early 2010s complaining how their new tall tubs couldn't clean.
YouTube videos of people cleaning gunky filters.
The only reason you hear less about it is because people just alter their loading habits (pre-rinse) until the problems are no longer noticeable. Which for many isn't that big a change because they've always been pre-rinsing due to the fact so many older dishwashers lacked good water filtration.
There must be some pretty poorly designed dishwashers in the States if that is indeed the case. Of course it’s always pertinent to take any online reviews/rants with a pinch of salt, as more often than not it’s due to incorrect use - and also bear in mind the phenomena that people don’t generally go online to tell everybody about their positive or neutral experiences where things are just working as it should.
I’ve cleaned the filter maybe two or three times on our current dishwasher in the year or so we’ve had it and the most that’s been on there is a stray cocktail stick. No gunk, just a quick rinse under the tap and that’s good for another however many cycles it is before the clean filter reminder comes back on (think it may be every 100 cycles).
There’s never really been a need to pre rinse with our dishwashers here, even with the older ones that used 15-20l of water per cycle. I don’t know anybody who does.
FWIW I’ve just unloaded two days worth of dishes from the load I did earlier, everything sparkling clean and it’s only used 10 litres of water, with no pre rinsing required 😊.
Some of it is misuse, as can happen even with the best makes.
However a manual clean filter can not handle the amount of particles, food soil and food bits the way a power clean module can. A Power Clean Module is truly self cleaning being able to shred, macerate, hold and flush large amounts of food soil.
In the early 2000s Power Clean commercials would place an entire frosted cake in the dishwasher and it would be gone end of cycle. I would really like to try that with a EU dishwasher.
At times, I load my gourmet pots, trays, and frying pans, and the "stuck on" food from cooking/baking is difficult to loosen.
Surely no dishwasher's got enough of water pressure to remove that grime.
Maybe a garden "pressure washer" would do something.
User pre-rinsing. Most Americans with a tall tub pre-rinse in various degrees. With the amount of water used pre-rinsing and pre-treating, it would make more sense to just add soap to a sponge spending a few extra seconds washing everything by hand.
With a Power Clean Filter Module water never touches anything beforehand. Tilt, scrape, load, accumulate and then run a cycle. Dishware, silverware, bakeware, pots, pans and other items can be loaded as is and can accumulate as is over a day or two. In just one cycle both dishes and the machine come out spotless, clean, film free and sanitized. No odors, no smells, no clogged holes, no afresh, no manual clean filters, no food bits at the bottom, no residue. Nothing left behind other than immuculate kitchenware.
Many gallons of water are saved along with the energy used to heat with a load-as-is dishwasher.
But but but!
All my older relatives with Powecleans STILL pre rinsed all their dishes.
So. Let’s say pre rinsing uses 20 gallons of water. And a PC normal wash uses around 6.5gal.
A modern dishwasher uses between 3-4 gallons a wash.
(These are ballpark numbers, don’t come at me bro)
Vintage + PreRinse = 26.5gal
Modern + PreRinse = 24gal.
26.5 - 24 = 2.5 gallons in savings!
And don’t get me wrong, I love my PC KUD23.
But it doesn’t get my dishes quite as clean as the Global Wash KA I had at my old house. And the PC is smaller and harder to load cookware/bakeware.
What Chet is FAILING to mention, is that the Americans who have clogged, stinky filters, are neglecting their machines. Americans are maintenance-averse. Or they might indeed have insanely poor or hard water.
In my experience, those with major filter issues are proponents of using the Quick cycle almost exclusively. Which means the final rinse never gets hot enough to emulsify built up gunk or sanitize the internals.
But but but!
Yup! I don't dispute that. In fact that is one of the core issues. Your relatives first dishwasher wasn't a Power Clean. Once a person uses a dishwasher without fine filtration, maceration, particle carry away, hot water, a reasonably long main wash and good water distribution they quickly into the habit of pre-rinsing. GE, Westinghouse, D&M, low end Maytags, impellar machines, ect guilty in one or more of those offenses. That habit often remains even after switching to a Whirlpool Power Clean Filter Module- so the user never discoverers what their PC is capable of. Once the Power Clean is switched to a tall tub, they don't come realize their new dishwasher can't clean because the pre-rinsing continues before, during and after.
If every dishwasher ever made cleaned like a Whirlpool Power Clean Filter Module the complaints would have been so pronounced tall tubs would have never caught on. At least not without some very serious re-engineering.
Or, you can skip the pre-rinsing with a Power Clean and use only 4.8 to 11 gallons of water. Or use a tall tub with 4 gallons of water per machine cycle while still using at least 20 gallons of water in the sink. 6.9 gallons of water average (PreWash-Wash-Purge-Rinse) is much less than 24 gallons of water. At least 4 times the energy and water use with a tall tub. No thanks.
Right, which is why you also need time and detergent.
Which is why the Power Clean Gives you two generously sized detergent cups and two long heated 140*F temp assured washes with a rinse in between.
Modern tall tubs don't give you two long temp assured washes. In fact the single main wash often doesn't go above 120*F.
Why do I need to clean a dishwasher? If it can't clean itself, why should I trust it to clean my dishes? Americans deserve better.
Because 3+ hour cycles are needed to compensate for the lack of spray pressure and re-circulation volume in tall tubs. Nobody wants to wait that long. Whirlpool Power Cleans typically did the job in an hour or less on the normal cycle while providing superior results.
Which is why the Power Clean Filter Module forced a 140*F thermal hold in the final rinse of all cycles (except rinse and hold) with electromechanical models and nearly all cycles with electronic models.
A thermal hold was default and could not be over-ridden. Whirlpool knew.
Problems that were succesfully anhilated came back to haunt tall tubs. How is that progess? It is not.
But manual clean filters can handle this. We’ve covered this before and you struggled to understand then. I’ve deciphered that perhaps it is more your opinion rather than fact that they don’t work, and that you prefer a non filter machine (which is fine), but facts prove otherwise that they do work. I actually wonder if you genuinely think we all have dirty dishes over here 😂.
You mention the cake test that Whirlpool did - in fact it is a test that Miele have performed throughout the years (there are videos on YouTube) which show the exact same test as you describe.
As I said in my previous post, when I check the filter on my machine when the machine occasionally prompts me there is never any food or gunk built up. The whole point of the filter is that food residues are held in the sump, kept out of the wash system, dissolved and flushed down the drain.
The Miele dishwasher I have will flush the filter with half a litre or so of water after the wash and before the final rinse to purge itself out, so that the filters are always clean.
Of course if I used the dishwasher like a waste disposal unit and purely used the quick cycles with inferior detergent then I have no doubt that I will have problems with gunky filters - but that would be my problem, not the dishwasher’s.
I get perfect results from my filter dishwasher everytime - whether I use the auto cycle (which yes is usually around 3 hours, but it’s really not a big deal especially if you’re putting it on in the evening or overnight). If I’m in a hurry I can get perfect results from the shorter Powerwash cycle which will do a 60°C wash and final rinse in around 1:20, using slightly more water to compensate for the shorter wash time. 😊
People are still complaining in the US about dirty filters, stink, food bits at the bottom of grate and poor performance.
The Power Clean Module also does a post main wash purge if it does not default to a full rinse before the final rinse. The difference is the filter is trully self cleaning.
Consider one of the techs here (Combo52) who despite his love for modern machines, still defaults to vintage Whirlpool Power Cleans after trying out several modern tall tubs. Power Clean even outperformed his Hobart Kitchen-Aid.
The Poweclean is great, but it’s not the be-all end all.
I am not a rinser.
I will still periodically get little yibbles and little leaf, or onion specs on dishes.
Because the PC still macerates everything and recirculates it.
Only a fraction gets filtered.
Something my past filter cup dishwashers have never left. Because the filter screens never let those particles through.
You love Whirlpool so much, yet you fail to give credit to them for their awesome filter cup system. It will self clean itself to the point where WP only recommends inspecting the cup 1-3 times… a YEAR.
WP also tested their Global Wash system on video, with a a chocolate cake AND cheese pizza. It was all gone with just a little brown Schmutz on the screen.
You have the advantage of a cold fill and lots of time which gives detergent enzymes time to work. So yes, more is getting dissolved by detergents.
In the US most main wash fills are around 120*F and heated above that. The pre-wash fills already warmed the dishes and cavity of the machines so the 120* charge does not cool down much below that at the start of the main wash.
US machines work best when the soils are macerated instead of dissolved, held in a chamber, flushed down the drain and said chamber is rinsed out with clean water all automatically.
For anyone ELSE visiting here. This is incorrect.
Sorry about the lala land impenetrable brick wall here.
Food soil is not different across the ocean.
You’re just experiencing American stubbornness.
