Work begins on the1957 Speed Queen TOL
Jon,
What a great job and fun machine. I used to have a '60's set back in the '80's and if I knew then what I know now I'd still have them. It was so much fun. I really miss them. Mine was like the one in reply # 5 and matching gas dryer.
Brian
Thank you all
for your kind words.
Ben I got it right, all that research and digging and feedback helped. I found out the Royal Purple was the same viscosity as the original just a tad thicker. So I used a mixture of half the original oil and half new RP filling to 3/4 cup.
The initial test was a little sluggish but I saw the cam bar needed a slight adjustment and performed that and whammo he took right off and spun a whole tub of water as you can see.
WOW!!!
that speed queen washer is BEAUTIFUL!!! you did an amazing job on the restoration!!! i can't wait to see "willie" filled with water, splish-splashing away as he agitates the laundry around!!!
OUTTA SIGHT job there jetcone!!!
;o)
Such wonderful progress on an arguably wonderful machine :)
At least it wasn't a very involved repair require unobtainable parts. That's a relief.
I'm with Washman on this - looking forward to some "Live Washing Action" of the machine!
puzzled..... was there a neutral spot between wash and spin......normally these jumped from the overflo agitation into spin......
am I missing something....or specific to this type of machine versus other solenoid operated machines?
otherwise...its still a beautiful machine......love that lighted console
Nope you are right Yogi
I had the "time" switch hooked up backwards too so the pause was really for the "7-2" minute setting.
Now all the switches seem to be wired proper, between the wh/red, wh/brown, wh/black, wh/blue, and white wiring it gets tight and confusing on the panel!
Always good to take pictures before you take things apart !
