All I want is a Maytag...
ooooh naughty!
ecstatically
ec⋅stat⋅ic  /ɛkˈstætɪk/ Show Spelled Pronunciation [ek-stat-ik] Show IPA
–adjective
1. of, pertaining to, or characterized by ecstasy.
2. subject to or in a state of ecstasy; rapturous.
–noun
3. a person subject to fits of ecstasy.
Origin:
1620–30; (< MF extatique) < ML ecstaticus < Gk ekstatikós, equiv. to ek- ec- + statikós static. See ecstasy
Related forms:
ec⋅stat⋅i⋅cal⋅ly, adverb
So without a donar machine for parts, this washer unfortunat
Robert, I wouldn't be too hasty to send this to Toyota's factory just yet. This is really such a rare find, I think it could even eventually be put in the future museum in MD even for dispaly. But, don't' forget there's that pesky ol ho-hum Norge in the Boston area. I bet a midnight panty raid (euphamism for raiding someone's washer basement) would yield a quite respectable donor machine.
I actually preferred this machine over ours because the 8 programmed buttons didn't offer the flexibility of this model and I cursed ours for that. I think mom chose our model because of the dispensers.
The thing that kills me about this machine still is the agitator. Soo similar to the solid tub Norge.. It's cool because I'm used to the big angel wing agitator w/ the perf tubs
Possible Good News
I spoke to Don (jetaction) this morning and he still has that 1972-1974 Montgomery Ward Washer sitting in his garage, you remember this one which also produced this recently. Greg, Don and I found that Avocado Wards washer on the street here close to my house back in 2006. I've determined that the Wards Signature that Fred and I just found is a 1964 model, the parts donor machine is a 1972-1974 model. While I'm sure the motor can be swapped, what I'm not sure about is if the Transmission parts are compatible. I guess we will find out, although this is going to be a lot of work and no promises, if I can't get this machine to work properly out it goes, no question asked, we cannot save everything and thinking you or telling other people they should is preposterous. So keep you fingers crossed everyone.
Here is Jon's (jetcone) video of the Norge version of this washer:
<object width=425 height=344><param name=movie value=></param><param name=allowFullScreen value=true></param><param name=allowscriptaccess value=always></param><embed src= type=application/x-shockwave-flash allowscriptaccess=always allowfullscreen=true width=425 height=344></embed></object>
Stand Back Boys
I like it when you get feisty, Robert. You are spot on true, it's not your's to save everything that falls into your hands. And it seems they will be falling faster now that you have an accessory!
Don't open the door!
Gosh, guess what a clamor would arise if you opened the door of a Toyota, made from a Norge, before it fully stopped?
Gotta save anything NORGE
They are not as plentiful as some of the other stuff...just BETTER LOL...my 41 inch range has some issues also, but it sure is different...anyone out there have any Norge service manuals...I sure could use one for my stove.
Request for Doctrine
Interestingly enough I found a <a href = http://www.automaticwasher.org/TD/ARCHIVE/MODERN/2006/7577x5.htm target=_blank>Thread from Nate</a> who found a Norge/Wards machine with the EXACT same symptoms as this machine to the T! Ohhh Nate what ever happened to this machine? :-D
Here is the parts list for the transmission in this Wards. While I have to take it apart to verify I suspect the problem child part is the clutch spring (part #9 colored in pink). When the motor turns the transmission pulley counter-clockwise this spring unwinds and allows the shaft it surrounds to turn freely and drive the agitator gears. When the motor reveres and turns the pulley clockwise the spring wraps tightly against that same shaft and meshes the shaft with the transmission housing which causes the entire transmission housing to turn. Since the wash tub is essentially bolted to the top of the transmission, both it and the wash tub spin, (just like in a Maytag).
Since I have a 1974 parts donor, does anyone have a parts breakdown the mid 70s Norge transmission? I'm wondering what if any differences there are between the two????
