Reality check again please: Your home heating costs
Prolly will be for me @ 14.3 cents/kwh. But teh new washer is helping with the drying, which is now taking about 22-26 minutes of heat per load, better than about 40 minutes of heat.
Petek,
Good work shutting down the fireplace flue.
Other things to check: Any ventilation fans should be checked to make sure they have working automatic dampers. These might be in the kitchen, usually over the stove, or baths. If there is no automatic damper, or the damper is stuck open, it's an open heat leak to the great outdoors.
Check for air leaks between the living space and attic. Bring a caulking gun and a couple of refills with you ;-). Pay particular attention to any modifications to the ceilings - such as new lighting, dropped ceilings, etc. Similarly for the usual weatherproofing around windows/doors/electrical outlets/plumbing on external walls. And of course the obvious set-back microprocessor-controlled thermostat. Lastly, 70F is a bit toasty for Canada in the winter - just my opinion. I keep mine at 65F and wear heavy shirts (thick flannel) or sweaters or sweats at home.
A more efficient boiler would probably help. Since the existing one is keeping the basement very warm, it's probably wasting energy doing that. It might be better to install a register in the basement - that can be controlled - rather than rely upon heat loss, which can't be controlled.
When I bought this California house, the two fireplaces had leaky dampers. Additionally, the stove hood had no damper at all, letting warm air go up the flue all the time. There were many air leaks between the living quarters and the attic. The force air furnace ducting in the crawl space had leaks as well, one quite large. There was zero insulation in the attic.
After addressing all these issues, the natural gas consumption in the winter dropped to half of what it was the previous winter. Plus, the home was far less drafty and much more comfortable. This despite a 1980 furnace in the crawl, which is probably not much better than 75% efficient, and which is now oversize for the better insulated home. One of these days I'll get around to replacing it with a modern unit.
trane owner here too
I replaced my old Coleman Evcon heatpump(2-1/2 ton unit) 4+years ago after it died( it was about 7-8yrs old. I'll NEVER own another coleman heatpump!) I will say it did work ok, but was LOUD. it was about 3 yrs old when I moved in here( single wide mobile home) the only problem I had was one winter I had to have the Defrost board relplaced, but the damage was done already.
I got a Trane XL 1000(10EER,2-1/2 ton) and have been happy with it, other than, the service guys for them around here are IDOITS for service work. I've had a few problems with mine, but it was do to VERY shotty work by the previous service guys. I won't go into details about that.
I keep my temp in the winter at 68( day and night) and summer A/C temp at 76( day and night)
My electric bill isn't all that high most months, under $80.00
Im a firm believer in heatpumps.
I was told by a guy that is a independant repair guy for all brands, to set your temp and forget it. It will cost you MORE to heat up/cool down a house, than maintain a steady temp. In the summer, have your furnace fan run all the time to eliminate hot spots, which I do and that has helped alot.
and btw, CLEAN YOUR AIR FILTERS 1x A MONTH!! I do mine like clockwork.
Rich
Glenn (Dadoes) and all:
Is there a cut-out temp (outdoor minimum during heating season) at which the heat-pump should not be run?
And Glenn, how can I be sure the electric coils are not energized when they should not be? I was thinking of putting an indicator light on GadgetGary's air-handler, with his permission, of course!
Hi Rich
Your points above are all on my mission list, to seek out as many leaks as I can find within reason starting with those easy fixes like the dampers you mentioned. Thankfully the previous owners put in new windows recently (except for the aforementioned 3 bathrooms which are being attended to temporarily with the stretch film till I can replace them) I know there isn't enough insulation in the ceiling over the bedrooms which would lead me to believe the same exists in the ceiling over the laundry/garage/sunroom which are directly below the bedrooms. That's gonna be tougher and will require blowing in from the small access panel in the ensuite bathroom down there. But I will say since closing that fireplace damper I've already noticed a difference. Obviously with the house being 50 y.o. it's never going to be as tight as a new build but I should be able to get it down to a more realistic level so I don't have to spend a fortune heating it yet keep it comfortable.. I dunno about less than 70 degs though,many people keep their places somewhere in the 60's even during the day but I find that too chilly, 70-72 is in the words of Goldilocks herself "just right" Funny thing is that for me anyways, 70-72 in the summer isn't just right, that's too chilly and I like the rooms about 75-76
Forgot to mention.. being a ubiquitous 4 level split, each level isn't the exact same temperature. It's warmest in the basement here, probably around 76, up 6 steps to the sunroom and laundryroom and it's a perfect 72, up 4 more steps to the kitchen/dining/livingrooms and it's a nice 70 (where the T.Stat is located), up 6 more stairs to the bedrooms and it's about 68. Those temps work for me. I figure that very warm heat in the basement is going to rise convectivly anyways to the other levels so I don't have a problem with it.
Armstrong Air
Well, I went and checked and we have an Armstrong Air Ultra V. It is Energy Star rated, I guess that is what makes it really effecient. See the link for more info.
We also have a whole house humidifier as well but I forgot to look at the brand.
I know our bills are cheap. I think the one that was the highest was last December at it was around the $200 range. I was baking up a storm for the holidays for several days straight, as well as having visitors that liked the house warmer than 70 (Arizona wimps).
http://www.airmechanicalinc.com/product283.html
Yep.....
We sold our 1400 sq ft ranch house in the country on 1 acre and had enough money to get into this one easily. Prices are going up like crazy in my county. In fact, Kendall county is the second or third fastest growing country in the US.
Petek
That's a great system you have there, it only needs a few tweaks around the house I think.
I have a Weil-Mclain, steam boiler with cast iron radiation. The best heat unless you can afford radiant floor!!
It will probably cost you about $1/month to keep the pilot lit on the boiler so take that off your calculation.
The worst offenders are that small draft you mentioned around the window, over hours that adds up to quite alot of heat loss. Do you have any window AC's left installed?
The next worst is the no automatic damper on the boiler flue, I bet your heat guy could install that no problem, it will keep your boiler hot between cycles.
Ever take your clothes out of your vented dryer in january and they are freezing cold after just being dried?? Now you see what an auto damper will do for your boiler.
Next biggest heat loss are those old windows and any crack you may have in the foundation. Do you have mice in the house? if so then you have heat going out cracks in the foundation--quickly!
It took me five years to replace all my windows in this house, 22 of them! I could only afford 5 a year, but when I got the last window in THEN i saw the annual bill drop from $1700.00 to $1400.00!!!
I have a 100 year old Victorian and it had the old lead weights in tracks beside the windows to raise and lower the sashes. Those tracks were a heating loss nightmare. You get those filled with insulation you'll see a big jump in savings.
I am surprised in Canada on the prarie that you only have scant 8" insulation in the house, I thought building codes were stricter up there, they are in Ontario I know.
Get that Pink Panther up there working!
cheers
jon & al
just paid my gas bill for November
$83 and some change, not so bad.
My furnace is a Bryant, vintage 2002. I no longer remember the details, but it is hi-efficiency, with the variable speed blower. I had a whole house humidifier installed, and the electronic air cleaner as well. I paid over $5000 for it, replacing the original 1972 furnace.
I love the humidifier, but have problems getting it set just right, as my windows get moisture on them, and my patio door out the back of the house will freeze shut complete with ice and such in the dead of winter.
Are there guidlines for setting one of those things?
9 degrees here this morning, furnace earning its keep for sure!
I love the humidifier, but have problems getting it set just right.
From what I hae seen the allowble relative inddor humidity needs to be adjust downwardly as the outdoor temperatures fall, to avoid just such problems.
Many controls as used on central warm-air heating systems are actually coded in oudoor tempertaures and show the analogous "allowable" (recommended) indoor relatiuve huimidity.
Methinks this is a month-to-month general adjustment rather than a day-to-day headache.
Steve,
my humidifier control is numbered 10-20-30-40... ect. For the fall months I had it set about 35, no static problems, and the carpet was sufficiently humidified to vacuum and actually get the dog hair up.
I think now I have it set between 20 and 25. That seems to be ok, window moisture is minimal at that setting.
My glasses still fog up everytime I come in from outside too!
Its DAMN cold here today, about 6 degrees when I got up this morning, I wish they'd figure out the heat here at work! Yesterday I'm in a heavier Armani sweater and I'm sweating all day, today I went for a lighter sweater over a t-shirt and I am freezing!
Toggles....
I was reading through rather quickly so I'm not sure if anyone answered your heat pump question or not. Heat pumps can be run safely at any outdoor temperature. They are pretty much self governing. They have back up electric coils in the furnace to help when it's really cold, and they kick into a self defrost mode on their own, when needed, to allow operation in weather below freezing.
Domo Arigato.
Thanks. I was jumping to the conclusion that the return-on-investment (of wattage) reached a point that simple resistance electric was just as economical when outdoor extractable heat (temperature) was low.
IMHO....
Keeping the electric heat coils from kicking in is important. My thermostat has 2 extra lights that glow when running the heat pump, if the coils are on. A green light, indicating that the "accessory heat" 2 assist coils are running in addition to the heat pump, and a red "emergency heat" led that glows, indicating that the heat pump has gone into defrost mode, and that 2 more coils have kicked on to assist as well. When either of these lights glow, I know to expect a much higher bill. I don't know the watt usage, but I can tell you it is significant. I try to keep my thermostat set below that point at which either of these lights glow, usually 69. It saves a bundle, using solely the heat pump.
Said: The worst offenders are that small draft you mentioned around the window.
It is impotant to have make-up air avaialble to your fossil-fueled heater.
Recommendation:
Get a dryer vent. Rip out the flap. Put a screen on it and aim it near the (ceiling of) the heater. With unrestricted air avaiable to replace what your heater dumps or forces up the flue/chimney, you will feel fewer drafts from all other sources. Without this, your system is forced to suck air in from every crack and crevice in the house.
This also helps the dryer and the exhaust fans have make-up air avaiable. These also cause drafts, BTW without make-up air.
Of course please ignore this post if you already have a mechanical heat-recovery ventilator.
http://healthandenergy.com/heat_recovery_ventilators.htm
I believe its relative humidity.
I know it does not say degrees on it thats for sure
Pete, do you mean that they had that fireplace damper locked open and no glass doors or anything blocking off the flow of room air all year??? My attic was poorly insulated also so the first year I lived here, I had 20 inches of these little tiny white fiberglass beads blown into the attic. Now, the ceilings under the attic are as cool as the floors and walls in the summer. Thanks to "deregulation," our electricity rates have increased over 20% in the last two years and natural gas has gone up a lot also. Now there is talk of re-regulating or un-deregulating, the gas and electric utilities. There was no competition like was promised when the dereg happened. PEPCO (Potomac Electric Power Co.) immediately sold all of their generating plants to Conectiv (sp?) which tried to declare bankruptcy a year later. BG&E (Baltimore Gas and Electric) used resources they had to try to buy Florida Flicker & Flash (FPL), but no one wants to beef up the transmission lines or increase generating capacity and with all of the growth in the area, we are dangerously close to peak demand exceeding peak supply. During a heat wave, there is precious little excess power to buy from other utilities and transmission lines carrying capacity loads make moving power to us a problem. The investors are making a profit, though, and that is the main focus of the game.
retroguy (and Toggles), I have an optional outdoor temp sensor on my system that reports the outside temp on the thermostat display, and also has the additional functionality of locking out the auxilliary heat strips until the ambient drops to a specified (user-adjustable) temperature. Auxilliary still functions, of course, during defrost or if system mode is set explicitly to Emergency Heat, but otherwise cannot run until the ambient temp limit is reached, no matter how much is the thermostat differential between room temp and setpoint. Normally the auxilliary triggers if there is more than a 2°F differential between room temp and setpoint, or if the system runs for a long enough time that an electronic thermostat determines it's taking too long to reach the setpoint.
I don't recall now what I have set for the limit. I think 25°F. Or maybe less. Probably as low as the setting will go.
The tradeoffs on running the compressor without auxilliary at low ambients are (under some conditions, such as wet weather) more frequent defrosting, and more chance that the system can't keep up with the load and the indoor temp will slowly drop below the setpoint.
Unless the system mode is set to Emergency Heat, the compressor *always* runs *with* the auxilliary at low ambients .... the compressor does not shuts off when the auxilliary turns on during "normal" operational conditions.
Here's the condensor (evaporator, actually, during heat mode) at my previous house a couple mins before a defrost cycle triggered. The weather is not below freezing, but it was wet/rainy with conditions being right for lotsa frosting.
Jon..did you miss the news,,we moved east and are now happily ensconced in Sarnia Ont. (actually the jurys still out on the happily part) so there'll be no more freezing prairie winds and it has been bitterly cold there for the last month. Well below zero even in Fahrenheit. Our house back there was well insulated, this one being a 50's model, well not so good but I've been in worse, like most 50's houses in the pacific northwest, Seattle, Vancouver, when it's cold outside it's cold inside.
Tom, yes apparently code requires that without an electric interlock on the damper door to shut off or stop ignition of the gas logs it has to be locked in the open position..well actually it's a screw lock you use pliers on. So it was like having a foot square gaping hole in the livingroom.
DADoES...
Wow....
That heat pump looks FROSTY! Is it possible that the defrost mode was set to come on a bit late? Asking because I've just not seen one look that way before. I know that mine must get some ice in it, as I've seen water pour out the bottom of it in defrost mode. But then, on my unit, the coil is enclosed. You can see it if you look through the top, the sides have down facing vents. It's a Ruud Scroll Inside model paired up with a GE Weathertron HVAC unit. When I had the GE heat pump replaced, the Ruud installer seemed to think the GE was far too small for the house. I'm not as well informed as I should be just yet! I'm sure it'll come in time. I am looking for a replacement for the Weathertron HVAC now however, to hopefully save energy dollars. I'm not really opposed to changing heat pumps again either, to have a strong, efficient, matched system. Any suggestions anyone? =)
I replaced my heating & cooling system this summer. I have natural gas forced heat. (as most people do here in Omaha) Will be interesting to see what my gas will be. (hopefully lower) I have a small 1922 bungalow with old windows. It must be insulated well tho because the house never seems drafty. My new system is a 93% efficient Frigidaire, and the previous system was a 1963 Sears Homart. I keep it set on 73.
Automatic flue,
Pete,
We have a large boiler here and we put an automatic flue on unit, (it opens when the gas valve opens and closes when valve is closed, it keeps the heat in the boiler instead of going up chimney, we saved between 200/300 month on gas costs, we heat about 25,000 sq ft. It all adds up,
Thanks
Kim
