To surgilator.
As I said to combo52 we both live in free countries and are fortunate enough to be able to express our views even though they, quite obviously, differ.
I am pleased that at least you agree that bleach could cause a problem if it was present in sufficient concentration. Is this correct? If affirmative we then have to look at how that could occur without improper use, is this correct? If affirmative please refer to the penultimate paragraph in my first post, can you understand it? Should you comprehend my theory, what is wrong with it? Should you not be able to understand it please tell me and I will endeavour to explain further.
This may surprise you but I totally agree with your second paragraph. All I have at the moment is very limited personal experience of washing machines, other of course, than using them, quite a bit of research on ‘the web’ and a theory. What I am asking you for is an objective criticism, positive or negative. I do however ask that the criticism be based on undisputable, verifiable facts.
I have to confess that I do not fully understand your third paragraph. How can what I have experienced, and read about, possibly influence what you list? I do not know. I do have to say though that there are hundreds, perhaps even thousands of posting on the web relating to corroded/failed spiders and bearing/seal failures. Are they all true, perhaps not, but I believe, and it is only my opinion, that the vast majority are true. Should you allow that something is causing those spiders to corrode and something is causing the bearings to fail early then we have to ask ourselves what? Here is a point to ponder. All manufacturers’ claim that their machines get the laundry cleaner, than whom, does not really matter to this thought, but would not one way to improve the performance of their machine be to remove more water and hence soil at the end of every phase of the cycle? This would mean that there would be less to contaminate, the next phase. This could easily be accomplished by ‘spinning’ to the maximum speed, now set for the final spin, at the end of each phase. Why do they not do it? Could it be that they do not want to shorten the life of the bearings even more? I do not know, just another theory.
The first part of your fourth paragraph again I cannot see what the point is. Yes I agree that on being presented with a corroded spider of unknown service(s) it would difficult to say very much other than it is corroded. However a diligent researcher would soon discover what could cause the corrosion whereupon said researcher may be able to formulate a possible plausible scenario.
For the second part of your fourth paragraph I do not believe I have said, on this thread, how our machine was used. So there is nothing to believe or disbelieve other than the machine was about 6 years old when it started to give off ‘the smell’ and was approximately 7.5 years old when the bearings failed. Quite bluntly I do not care if you believe that or not, it makes no difference to my theory.
From your fifth paragraph I can see how excess detergent particularly of the powdered form could contribute to corrosion. Proctor and Gamble even state on their own MSDS for one of the powder ‘Tides’ that the pH is 11.0, that is one thousand times more alkaline than the safe level of 8.0 for aluminium. Add to that incomplete dissolving in cool/cold water and, in my opinion, you have a recipe for disaster.
As for bearings failing of their own accord, what about a bearing with a manufacturing defect, as with anything the odd one gets through, or what about one noted to have brinelling damage prior to attempted installation? That damage would not have been there on completion of manufacturing. I have to disagree with you, ball and roller bearings do wear out even when properly installed, not overloaded, properly lubricated, no foreign bodies or liquids allowed to enter and otherwise correctly maintained, they do just wear out. Even automobile manufacturers normally give a service period after which renewal is recommended. What do you think happened to the bearings in the second machine I dismantled?
With respect to your sixth paragraph, you will have your opinion and I will have mine. As to whether it was done deliberately not is another matter. Even the best designers and engineers make mistakes, the really good ones acknowledge them, correct them, and then move on.
