Whirlpool Washer
Slower.
If I am remembering correctly, Maytags spin at 618 RPM and regular capacity WP/KM belt drives spin at 525. Of course, the diameter of the tub makes a difference in G-forces and length of the spin cycle will also affect extraction. Both numbers above are on regular speed settings, not slow.
Confused?
Dave
Agitator out for cleaning.
The Gadget thinks the finish was worn off. I say this is some type of scuzzy coating.
I will try to abrade it off.
Nekked drive post. Unlike a low-drive Maytag, this brand drives that agitator the top, just like a GE.
Notice those brown spots....
Can't tell if this is damage from (under)a missing glaze, or damage under some kind of crud/coating.
Lid swtch.
Energizes and de-energizes solenoid that travls on oscilating wig-wag. Starts and tops spin (only) on this machine; will fill with water and agitate with lid open.
Low-tech solution to low-tech problem. Pencil with metal tip cut off (catered reception to follow the bris) and rubber-bands as motion-stops defeats lid switch.
Look ma! No wire cutting and splicing!
That is one SUPER Surgilator
I love that style of Whirlpool! The dials and the console are awesome...Once I am sufficiently full of 'Tags I want one of those...
Hope that isn't a rusted tub...Hope it is scum that will easily come off.
I can almost hear the surgilator slurp as it wig-wags away.
After a full fill and hot wash with bleach (to clean deodorize and disinfect),she is ready to wash her maiden load at this address.....
WHAT FUN and familiar sounds!
Spin speed;
I know that standard capacity BD Whirlpools/Kenmores spin at 525 rpms, but I believe I read somewhere that large capacity models are even slower at 505 rpms. Is this accurate?
She looks awesome all cleaned up and washing. Congrats on getting her.
Have a good one,
James
Who washed a boa in there?
When we got Maggie(her proper name) home, we kept finding feathers in the washbasket. At first, we were grossed-out as they kept pouring out of the Magic-clean filter(we just assumed that a bird or animal met its maker). We later had an AHA moment when we realized it was probably the remnants of a down comforter or pillow.
James
As an experiment, we took the finished load out of Maggie (this Whirpool)and stuck it in The Mutt (one of my Maytags) and ended up with 2-1/2 cups of additional water removed.
(575ml @230ml per cup).
The tub diameter of the Whirlpool is only a bit bigger than that of the Maytag.
Even worse, what is the spin speed on Gentle cycle?
Strangely the rust-color is UNDER a coating of what I believe is lime scale
The Gadget says the next town over, where she lived, has very hard water.
Chipped it out with a utility knife.
